Question about Hotpoint RB526 Electric Kitchen Range
"BAD LINE" MY STOVE IS DISPALYING "BAD LINE". I HAVE TO DISCONNECT IT TO STOP THE BEEPING SOUND. WHAT DOES THIS USUALLY MEAN?
    Sergeant:
    Champion:
  • 208 Answers
Most likly it's a problem in the electrical going to the stove call an electrician
Posted on Jun 22, 2009
  • Kimberly Kuhn
    Kimberly Kuhn Jul 28, 2014
    Could this mean the appliance cord is bad? Or is it more serious?
When start pedaling it makes a beeping noise that will not stop
Sorry, but more information is needed;
What do you mean a "Beeping" sound ?
Beeping is usually associated with electronics.
Do you mean like something is rubbing, perhaps a brake shoe along the rim, or a metal on metal sound ?
I am assuming the sound stops when you stop pedaling or stop the bike's motion - one or the other - which is it ?
Oct 04, 2015 | Cycling
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
How to disconnect beeping hotpoint stove digital timer/clock?
Good Afternoon Patti,
I understand that your Hotpoint stove digital timer/clock is beeping and you are wondering how to disconnect it. I suggest resetting your stove by either unplugging it or disconnecting the power at your home's circuit breaker for 3-5 minutes. When power is restored, if your stove is still beeping, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what the cause of the beeping is. They will also be able to assist with repairs, if needed. Hope this is helpful.
-Best Regards-
WP
May 06, 2014 | Frigidaire FEF336BC Electric Kitchen Range
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 19, 2014 | Thermador Ovens
Ge true temp oven
I think the problem stems from working on the board with the power on. MicroProcessors don't like that. If by "popped" you mean made a frying noise, you are going to have to replace the board.
Nov 27, 2013 | Ovens
Our stove is beeping and will not stop. How do we get the beeping to stop?
Make sure timer, oven and all top elements are off. If beeping continues, completely disconnect
power for 45 seconds. Then reconnect. Follow mnfr instruction for setup.
Dec 18, 2010 | Kitchen Ranges
"F1" DISPLAYED AND BEEPING
hi there,
the F1 code usually means that you have a key stuck on the keypad. unplugging it from power won't make a difference for this one. is it a wall oven or a stove? can you supply the make & model please?
Oct 03, 2008 | Ovens
F1 code. Stove is beeping
F1 defective touch pad or membrane. 1. replace touch pad or membrane ( this problem is usually the touch pad).
or
F! watchdog on board. 1. replace touch pad or clock assembly (also called the ERC).
Aug 25, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air range model SVE47600 Beeping
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
Hotpoint RB526 Electric Kitchen Range Logo
662 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
