Question about Dynacraft Cycling
Dynacraft Barbie Big Wheel replacement back wheels
    Problem Solver:
  • 19 Answers
I expect you need to find 16in wheels, you could always contact the manufacturer for more help: http://www.dynacraftbike.com/customerservice.php
Posted on Jun 15, 2014
  • 1137 Answers
SOURCE: where to purchase new training wheels for the
I see at least 7 bicycle shops in your area. The training wheels don't have to be made by the same company that made the bicycle. Phone around to the various shops and give them the same info you posted here. If you don't feel comfortable installing them yourself the shop you choose will be able to install them easily. Please let me know if this helps.
Posted on Nov 20, 2009
  • 384 Answers
SOURCE: how do I attach the hadlebars?
the bars go throuhg the hole down into the front wheel. on the bar where the the neck goes into the frame there is a hole in that a long bolt goes in that, then the wedge shape nut goes on the long that runs down the neck into the frame that the front is in. make sure that the wedge bolt will line up with wedge on bar. place through frame into wheel so the neck bottem out get your ratach and start cranking as it get tight line up neck w/ tire and lock it down pull up to check turn head just in case
Posted on Feb 22, 2010
vincob
  • 718 Answers
SOURCE: How do you change the inner tube on dynacraft
What do you mean you can't take the wheel off if a man/person put it on you surely can take it off, step back look at the situation and get er done!!!
Posted on Apr 08, 2010
  • 70 Answers
SOURCE: where do I find a replacement tire for a barbie
Its either a 12" or 16" tire replace with any tire you like in that size
Posted on Aug 16, 2010
SOURCE: i need a new back
You can contact dynacraft directly but you have to give them the serial number of the trike. http://dynacraftbikes.com/contactus.php
I have the razor scream machine which is made by the same manufacturer but dynacraft won't sell me the wheels unless I give them a serial number from their hotwheels powerslide model. Could you post the serial number on your trike? It would really help out myself and all the other scream machine owners who currently can't get replacement wheels.
Thanks,
-Alex
Posted on Sep 12, 2010
I can't get the front brake close enough to the tire so it stops
Firs, put a clamp (or a helper) to hold the working end of the brakes against the wheel rim, this will make the brake cable loose. Now loosen the "anchor bolt" (see three different kinds of brakes pictured below) where the cable attached, then pull the slack out of the cable and retighten the anchor bolt. That provides a big adjustment. Now to make a finer adjustment, use the adjusting barrel. Good luck!
Jun 17, 2012 | Dynacraft Girls 16" Barbie Bike
Need back tire for barbie bike.where to get?
I imagine the tires have a brand name and their exact specs embossed on the sidewalls. Hit the search engines and eBay. You may end up having to get a new pair if color match is important. ANY bicycle shop and many big box stores that sell kids' bikes will carry something that will fit.
Jun 15, 2011 | Dynacraft Girls 16" Barbie Bike
I can't get the front wheel fork to fit. It seems like it is not wide enough to fit (I have taken off the washers and bolts on either side). Am I doing something wrong?
You're doing nothing wrong. Dynacraft is notorious for this. All you need to do is flex the arms out a little bit at a time. A bar clamp set for expand normally works. the general idea is to work both arms at the same time to make sure is stays centered.
Dec 20, 2010 | Dynacraft Girls 16" Barbie Bike
The training wheels won't reach the ground. I loosened them and lowered as much as possible and theare still above the back tire and will not touch the ground at the same time
The training wheels are not meant to be as low as the back wheel. The idea is that the child learns to balance the bike but if it goes over to one side the training wheel touches the ground and stops the bike from falling
Where to find replacement wheel?
At any sporting goods store like Sport Authorities, Sport Chalet or Big Five.
Aug 18, 2010 | Dynacraft Barbie Aluminum Scooter
Where do I find a replacement tire for a barbie dynacraft bike?
Aug 16, 2010 | Dynacraft Girls 16" Barbie Bike
How do you change the inner tube on dynacraft slumber party bike. I can't get the wheel off.
Apr 08, 2010 | Dynacraft Girls 16" Barbie Bike
How to unfold the scooter
there should be a silver latch near the base that you hold to release the handle. The lever i think is by the front wheel on my daughters... hope this helps
Dec 14, 2009 | Dynacraft Barbie Aluminum Scooter
Where to purchase new training wheels for the dynacraft barbie 16 inch bike? st. pete, fl
Nov 19, 2009 | Dynacraft Girls 16" Barbie Bike
Fork is too narrow for front wheel
One solution, is a large, wedge shaped piece of wood.
Try hammering that into, or the forks onto it.
That should open them up, without damaging the finish.
Good luck with that.
Jul 22, 2009 | Dynacraft Girls 16" Barbie Bike
Cycling Logo
78 people viewed this question
Top Dynacraft Cycling Experts
Tony
shaun taylor
Mike
Are you a Dynacraft Cycling Expert? Answer questions, earn points and help others
