Question about Whirlpool Duet GHW9150P Front Load Washer
M/c is not running, only show low beep sound with water reuse
Problem occured low beep sound with water reuse after choosing any mode option of wash
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: My washer is running the
The computer might not have confirmation of a full tub of water n the alloted time. Their could be some junk in the water level pressure tubing. Take the top off and remove the hose. Blow it out to remove any sedement that might be in there. Won' cot nothing to try. The flow meter measures the amount of water a goin in and when the computer thanks the water in their is anuff then it needs ta get a confirmation from that pressure in the tubing. if you got some junk in there the brains won't get that confirmation and the whole shebang will come to a screachin halt for fear of floodin.themobilian_500.jpg
My notes:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
Your tech sheet is located behind the base panel. The handy hippy has made a nice video HERE
Posted on Dec 19, 2010
richroth
  • 9472 Answers
SOURCE: Hard water
What is the model number of your unit?
Posted on Nov 12, 2012
richroth
  • 9472 Answers
SOURCE: OK , MY WHIRLPOOL DUET WASHER WFW9150WW01TURN TO HAVE PROBLEMS,ITS RUN THE CYCLE JUST FINE BUT IT DREAN NOT TOO GOOD STILL HAD SOME WATER LEFT OVER, AND ITS NEVER SPIN AT ALL, DOOR LOCK LIGHT AND WAH
Remove the lower panel and clear the filter.
Posted on Nov 25, 2012
Fisher
You need to enter the option adjustment mode:
1. Plug the machine in but do not press POWER.
2. Press and hold the Start / Pause button, then press Power
3. Three quick beeps will be heard and the machine will show an unusual pattern of lights.
4. Carry out any option adjustments necessary.
5. Press POWER to return to normal mode.
May 05, 2013 | Fisher and Paykel GWL11 Top Load Washer
I have a GWL11 Fisher Paykel washer. It was running fine then it was beeping and had stopped-- the spin light was the only one left on, although water is in it. Basin looks lower than I recall. It won't...
Hi just read you posting.Now when the machine was beeping was the spin light the only light that was on while it was beeping?If this is the case then my manual tells me your Motor Controller is faulty and needs replacing.Please confirm which light was on when the machine was beeping because the motor controller module is not cheap.Looking forward to your reply.
Jun 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
My computer allways restarts after a blue screen in windows. what can be the problem ?
This is what we refer to as a blue screen of death. This generally means Windows is damaged or has bad configuration.
If you recently changed something in Windows such as installing a new hardware device please disconnect and reboot.
If you installed new software you will want to put your computer in to safe-mode to uninstall it.
  1. Turn off your computer
  2. Turn the computer back on
  3. After the beep, continuously press and release F8 on your keyboard every 1 second
  4. You will be prompted with a list of boo-up options. The options vary depending on which OS you are running.
  5. Choose SAFE MODE
  6. Once your computer boots up, click Start, then settings, then control panels
  7. Open Add/Remove programs and uninstall anything you installed before the issue occured
If this issue just happened without any changes try these steps
  5. Choose Last Known Good Configuration
  6. Windows will attempt to do a simple restore of its configuration files
If all of the above fail your best option is to talk to a PC technician in your area.
Aug 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Only one of the wash cycles on my Maytag Neptune TL washer still works. Nothing happens when you press the other buttons. Most of the lights for the additional options are out too (e.g. water temperature -...
Is it a FAV6800AW or FAV9800AW machine? Sounds like it is. I believe you have a Control Board issue; the Control Board has a 5yr warranty. Do you want to DIY a fix or call in a Appliance Repair Tech? Have you reset the 120VAC power on the machine? If not give the Control Board a hard reset by pulling the washer power plug for 10 seconds or so and then re-power up the machine.
I’ll attach the Service Manual link located on this site for reference. See if you can get into Service Mode, try this.
To enter Service Mode, this from the SM.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys simultaneously for three seconds or until the control beeps. The Console display will show “00”.
Access Board Output Test by pressing the Delicates key. The console display will show “ot”
The lid lock will lock and the Quick Wash LED will be lit. Will the machine allow you into Service Mode? If not then it’s time to replace the Control Board. Press the Off button to back out of Service Mode.
Let me know what direction you want to go. Rich
Jul 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Machine seems to have balance off with every load and beeps.
Make sure that the washer is completely level. If it is not, adjust the foot screws.
May 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Beeping
the beeping usually is there to tell you something.
It is possible there is not hot water being supplied when you have hot or warm selected
Maybe the water is filling to slow
maybe the filter i clogged
maybe the barrel is out of alignment ( cased but imbalance from previous wash )
is it a top or front loader.
what lights flash when the beeping occurs?
Mar 21, 2009 | Whirlpool GHW9400 Duet Washer
My Bosch washing machine shows error code F37 and beeps
My Bosch washing machine shows error code F57 and beeps
Dec 09, 2008 | Bosch Logixx WFT 2806 Front Load...
Spin
Electrical module fault
The “Spin Speed” indicator and the “Start
Delay”
option are flashing and an audible tone
sounds. The display shows “F4” to “F16”.
Switch off the appliance. Select a programme
and press the “Start/Pause” button once
again.
The programme will continue.
If the fault re-occurs, contact After Sales
Service (see “After-Sales Service”).
the user man can be found here
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Jan 15, 2008 | Whirlpool AWM8163 Front Load Washer
Machine not filling with hot water
First check the filters in the inlet hose and hot water pressure. Sounds to me like the hot water valve is faulty. Test the w/machine on a hot water cycle, if you hear a noise and its not filling it up with water,its a faulty hot water valve. Air pressure?? change the water valve and remember it has a little rubber boot on the old water valve, transfer this to the new valve,or go into option adjustment mode and change you wash temperature settings.
Aug 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
