Question about Vacuums
How do I get access to the power switch?
The issue is how to open up the cleaner, to replace the switch. It seems to use pentagonal hex nuts (maybe 3mm dia) at the bottom of the slenderest access tube - no hope at all of my master-craftsman's magic-tool kit getting to these, so I have chiselled out the plastic around the push button switch, and now I have to drill out the switch itself.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
To what unit?
Posted on May 06, 2014
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i fix the brushbar on my vacuum cleaner there are three switches - power switch , brushbar switch ,and reset switch ,the latter does'nt seem to click ,should i replace this one
make sure you're getting power to the brush bar switch. If so there is a micro switch that activates the brush bar when you pull the handle back into the vacuuming position. Make sure that micro switch (in the ball assembly) is getting power from the brush bar switch.
Apr 08, 2015 | Dyson DC25 Animal Upright Ball Bagless...
How do you fix a red Hoover windtunnel 2 rewind pet vacuum (model UH70830)? Since me and my 1year old corgi have arrived at my moms place, I've been using her Hoover vacuum cleaner off the hook because...
It sounds like there's a problem between the power cord and the vacuum cleaner itself. Remove the power cord check the connection at the vacuum cleaner and see if something came unconnected
Nov 18, 2014 | Vacuums
Doesn't spray
Hi There,
If your shampooer not very old more likely you have not corrosion issues. To make sure the pluming is clear, flush the pipes and the nozzles. To access these part of the machine you have to open the bottom cover (remove watertank and screws).
In the spray system some components are involved: solenoids, trigger switch, rubber piping, heater block and the pump as the heart.
If you can you should check the pump running or not. The pump is a small 12 Volt motor (gets power if the vacuum motor (120 Volt!) is running, connected in series through a
bridge rectifier). If you can, measure voltage on the pump connections (be aware of line voltage). If no voltage detected, it could be the rectifier or it may has a blown fuse, which is hidden in the cable bundle (120 V/3.15 A).
You should follow the wires from the pump, the fuse is insulated with a pice of heatshrink. Open up and measure continuity. If the fuse is broken, try with 12 V (car battery or power supply?) the pump only. If it's running smoodly, replace the fuse (could be tired for some reason and broke). After the pump is running it should spray trough the nozzles. Hopefully this would help and get going your broken Bissell.
Good Luck!
Mar 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover HWD-20 how do I open/access the switch and motor section?
I\'ve discovered how to get the cover open.
There are four grey inserts on the top of the machine that are used to store the power cable. If you pull these up and out
(takes a bit of force) they reveal four small star screws that are somewhat difficult to access. They can be undone with a
small long handled hex nut though.
Once the screws are undone, lift the cover carefully because the switch is connected to the top. Carefully put your hand inside
the machine, having made sure the device is disconnected, and push the switch through and out the top. Then write down how the
wires are connected, red and blue on the "O" side and for the two black connectors first make a small notch with any device or
wrap some coloured tape around it etc so that you know which is which (Though technically it shouldn\'t matter). The crimp curl
overs point away from each other. Pull the crimp ends off.
There are then three slightly larger star screws to remove. You\'ve now access to the devices internals.
Do in reverse to re-assemble.
There isn\'t actually much one can do once inside the device, it\'s suprisingly well made with very little dust penetration even
after a lot of abuse. Other than the difficult to get to screws I\'m impressed with Hoover.
Nov 13, 2011 | Vacuums
The motor in the vacuum will not operate. With the unit plugged into power the green light goes on but the motor remains silent. When the power head is attached it does not operate and the lights on...
Vacuum cleaner repair manuals seem rare and difficult to obtain. The instruction booklet does not contain dismantling and repair details because to do so would make them responsible for encouraging incompetent people to electrocute themselves.
Vacuum cleaners are generally fairly intuitive to dismantle and the circuits fairly simple. The switches are sometimes found to be faulty but it would be wise to assume nothing. I once scrapped a cleaner assuming the motor was defective in the absence of other faults but when I had already removed everything but the motor, when I finally lifted out the motor I found a (faulty) bimetal thermal breaker...
May 06, 2017 | Sebo Air Belt C3.1 Bagged Canister Vacuum
How to change belt on sears vacuum cleaner
I believe you turn the vac over so the beater bar (brush) is facing up.
Depending on the age there maybe screws or tabs that hold the plate on to the bottom of the unit. Remove those and the plate. That should expose the bar, belt and motor pulley. If the beater bar doesn't pop out when the bottom plate is removed, pull it out and remove from belt. (Pay attention to how the bar was inserted. It may have a pentagonal shape and only fit properly when inserted a certain way.
Now is a good time to clean the beater bar.
Replace with correct size belt and reassemble in reverse order.
Hope this helps.
If so, please rate me.
Thanks,
Matt
Sep 14, 2009 | Kenmore Vacuums
The switch on our Hoover Windtunnel vacuum cleaner is not working. I have located the replacement part on your website...part#Ho-28161067, I've removed the wires from the switch. Is there any trick to...
no, follow the directions to replacing the switch and you should be good. if you got the kit then splice the wires and replace them with the wires profied and the wire nuts, you should be good.
Jul 20, 2009 | Vacuums
Kirby ultimate g handle staying upright
Please see my online guide for replacing the power switch. It will get you into the case. Just use this link....
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps...
Marci
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
