Question about Samsung Washing Machines
WA13G7Q1 Drum oscilates both left and right but does not want to pick up revolutions
    Problem Solver:
  • 11 Answers
Check Belt tension. The belt may be slipping
Posted on May 22, 2014
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
Paper jam p1005 hp printer
Load paper, give print command verify weather pick up roller trying to pick paper?.. >if yes check pick up roller surface feel smooth?, replace it.. >if no remove right,left and back covers, check solenoid jammed? release it.shoot print command check> if solenoid not acting replace it and verify..
Jan 09, 2012 | HP Office Equipment & Supplies
I have a marantz m6100 turntable and it seems like the clutch plate is locking everytime the gear drum wheel makes a full revolution. Once it catches - it then makes a constant clicking noise (kind of like...
Check on vinylengine.com for a Users Manual. You can download it for free once you register. The gear wheel might not be set right. If that doesn't help, pick up a 6100 Service Manual. I think I bought mine on ebay for about $10
Apr 19, 2011 | Marantz Audio Players & Recorders
Drum won't spin on its own, makes a low buzzing
either your bearings have gone or u have something trapped between inner and outer drum
Mar 20, 2010 | Washing Machines
Noise from drum when spinning.
can u move the drum up and down if so the bearings have gone
Feb 03, 2009 | Whirlpool AWM8163 Front Load Washer
Bump
Look for a crack on the seam of the drum, right at the front or rear of the drum.
Dec 29, 2008 | LG DLE2512W Electric Dryer
ABOUT MOTOR CAVALIER 1999
i guess you are talking of the engine increasing the idle speed and decrease in the idle speed amd i right? assuming this is what you are talking ablut, there are several factors to look into but the main sourcefor what we call as engine surge is vacum leak
Nov 06, 2008 | 1999 Chevrolet Cavalier
Belt broke on GE Dryer model #DDE7500BALWH
You will need a WE12X82P belt, or just a WE12x82 (the P stands for packaged)
  • Disconnect power
  • Remove screws under the front edge of the dryer top
  • Swing top up and remove one screw from each side panel holding the dryer front, near the top of the dryer.
  • Pull dryer front forward a bit and lift off bottom pegs. Swing to the side. (no need to disconnect wires if you don't want to)
  • Put belt around drum, lifting drum a bit to get belt past drum support slides on the bottom side.
  • Check to make sure drum slides are not worn through, especially the one on the left side.
  • The grooved side of the belt touches the drum
  • Belt runs from drum directly to motor pulley on the left side, then around belt tensioning wheel and back to the drum.
  • Turn the drum a revolution or two (counter clockwise) before reassembly.
Oct 04, 2008 | Dryers
Washing Machines Logo
61 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
