What is the best way to get access to the power switch?
The issue is how to open up the cleaner, to replace the switch. It seems to use pentagonal hex nuts (maybe 3mm dia) at the bottom of the slenderest access tube - no hope at all of my master-craftsman's magic-tool kit getting to these, so I have chiselled out the plastic around the push button switch, and now I have to drill out the switch itself.
  • Nothappy Coustumer
    Nothappy Coustumer May 06, 2014
    This is a Hoover VACUUM CLEANER - don't know how it ended up under washing machines?
aborcass
  • 2651 Answers
SOURCE: amana washer
PULL,PULL. turn your head and pull!!!!!!!!!, your also gonna need some adhesive for that seal kit silicone wont work
Posted on Feb 25, 2008
  • 1462 Answers
SOURCE: Hotpoint Aquarius 1100 washer dryer
probably not door switch, but to access, remove door gasketf rom cabinet in area of door switch and door switch is only held by 2 screws. more likely to be the suppressor capacitor. remove top and look at suppressor - they sometimes go pop
Posted on Aug 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: need to find pressure switch tube
Remove the rear cover on the controls
Posted on Jan 19, 2009
SOURCE: washer will spin but wont agitate
Pull straight up on the agitator
Posted on Apr 15, 2009
  • 100 Answers
SOURCE: How do I get access to the power switch?
To what unit?
Posted on May 06, 2014
How do i fix the brushbar on my vacuum cleaner there are three switches - power switch , brushbar switch ,and reset switch ,the latter does'nt seem to click ,should i replace this one
make sure you're getting power to the brush bar switch. If so there is a micro switch that activates the brush bar when you pull the handle back into the vacuuming position. Make sure that micro switch (in the ball assembly) is getting power from the brush bar switch.
Apr 08, 2015 | Dyson DC25 Animal Upright Ball Bagless...
Why won't my vcr insert tapes?
Assuming there is power going to the machine, and the display is illuminated (showing clock for example), and the deck is empty, it sounds like a mechanical fault - could be worn belts or gears, but could also be a faulty/dirty mode switch (this can cause a lot of issues including failure to eject/load) - so tackle the simplest problem first - look at the belts and/or gears, especially those on the carriage/cassette cradle assembly; see if any are worn or broken.
If any belts are stretched or any gears look cracked (manufacturers used plastic gears which are often weak), see if you can order replacements. If those check out OK, next step is to examine the condition of the mode switch. To get access to this: unplug the VCR from the power point, and carefully open it up and locate the mode switch (usually UNDER the deck) and spray a little bit of CRC-2 electronic switch cleaner into the switch cavity (if the switch is a rotary type, gently rotate it in both directions to work the CRC cleaner into it - don't use too much - the cleaner evaporates but it will clean the contacts inside the switch and leave a fine lubricant to minimize wear). You do not need to open the switch or remove it. Then carefully re-fit the deck, connect everything (heads etc.) You can purchase CRC electronic cleaner from most stores (this is usually a small aerosol can with a hose attachment - ideal for switches and contacts). Then plug VCR in and test (use an old tape which has nothing important on it). If it still won't accept tapes, it's likely to be a mechanical alignment issue which requires a technician to correct as there may be broken or worn gears. (generally you cannot replace these efficiently or reliably by yourself without some experience, a gear/belt kit and a service manual to help you.)
*** I DO recommend you look at the belts and gears to check their condition FIRST before disassembling the machine or going any further. ***
Advice: being a modern design VCR, it's likely to have lots of flimsy plastic gears and other parts which break easily and may not be replaceable.
Feb 13, 2015 | Televison & Video
When I turn on my KORG C15S often it blows 1A Fuse. It seems as a power supply unit problem. Any suggestion for repair? Please help
It's likely capacitors discharging, then re-charging during power-up weakens the fuse element. Try a slightly bigger fuse (1.5A)
Also, if you have some contact cleaner (NuTrol is best) try cleaning the power switch as intermittant action can confuse switching supplies.
Nov 10, 2014 | Music
Dryer wont heat
try doing cotunity on door switch
Jan 22, 2013 | Kenmore Dryers
After I make a turn - it sounds like my turn signal is staying on - but the light is off - it just makes the clicking sound - it only does this occaisionally - my car is a 2003 chevy malibu
This is a pretty common issue with many gm models. What happens is the multifunction turn signal switch is supplying a ground for the power from the flasher causing the flasher to think the turn signal is in a left or right position. I have heard of some cleaning the turn signal multifunction switch with electrical cleaner to solve this issue. The steering wheel trim covers will need to be removed. Have a rag handy to catch the drips. Spray every nook and cranny of the switch you possibly can with the contact cleaner. If this works problem solved. If it doesn't than the switch will need to be replaced. I can give you some basic instruction on how top replace the switch if needed. If you have any questions I will try my best to answer them.
Sep 06, 2011 | Chevrolet Malibu Cars & Trucks
The motor in the vacuum will not operate. With the unit plugged into power the green light goes on but the motor remains silent. When the power head is attached it does not operate and the lights on...
Vacuum cleaner repair manuals seem rare and difficult to obtain. The instruction booklet does not contain dismantling and repair details because to do so would make them responsible for encouraging incompetent people to electrocute themselves.
Vacuum cleaners are generally fairly intuitive to dismantle and the circuits fairly simple. The switches are sometimes found to be faulty but it would be wise to assume nothing. I once scrapped a cleaner assuming the motor was defective in the absence of other faults but when I had already removed everything but the motor, when I finally lifted out the motor I found a (faulty) bimetal thermal breaker...
May 06, 2017 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Hayward Navigator just had shoes and wings replaced. Everything seems to be working but moves extremely slow, even when suction is increased.
Did you have the turbine and A-Frame inspected or the gear box at the back of the cleaner looked at? Hayward Navigators are 100% repairable and most every pool store carries every single part to make the repairs. If these parts are also worn down, you will notice performance issues with your cleaner.
Before we assume the worst, lets run the cleaner through a few inspections.
Simple Troubleshooting for your Hayward Navigator When It Is Not Moving
The most common reason the Hayward Navigator stops moving is there is something blocking the mouth of the cleaner. Pull the cleaner out of the water while the equipment is turned off and make sure the cleaner is not clogged with debris or plugged with a pool toy. Also, make sure that all the internal components are properly installed.
Not Enough Suction - Next, verify that there is enough suction to allow the cleaner to work properly. While the pool equipment is on, lift the Hayward Navigator to just below the surface of the water and feel to see if there is a reasonable amount of suction getting to the cleaner. If there doesn't seem to be enough pressure, make sure all baskets are clear of debris, the main pool filter is clean, and that the diverter valve is open to the pool cleaner.
Small Debris Inside the Navigator - If there seems to be enough suction getting to the Navigator, but the pods are not moving back and forth, there is probably some small debris inside the cleaner that is stopping the turbine from moving. In order to remove any debris from inside the cleaner, remove the small access cover from the bottom of the cleaner by loosening the one screw until the plate pulls off. Use your fingers or the hose to clean the inside of the cleaner out.
If following these simple troubleshooting tips doesn't correct your cleaner issue, there is probably a mechanical issue. Take your cleaner into a local swimming pool retailer or have a service company out to assist (though most pool stores will not ever charge you for labor to make repairs!)
Thank you for posting your question on Fix Ya! I hope to have been of some help to you regarding this issue and if you need some additional clarification, please feel free to let me know what happened with your cleaner! We also appreciate your feedback in letting the world know if you were satisfied with our help!
The Ugly Pool Guy
www.WeFixUglyPools.com
Dec 11, 2010 | Hayward Navigator Pool Cleaner
Self-propel switch arm broke off where control cable was attached. Looking for instructions as to how to gain access to that switch arm to replace it.
Greetings from GoVacuum,
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
We have also put together a very helpful video for your vacuum cleaner on how to replace the belts. The belts on this model are also a frequent issue we see with these self-propelled Winddtunnels. In fact, for best results you should change the belts once a year, even if they are not broken, because they do heat up and stretch to a point where they don't work as well as a new belt would. The video also explains how you can maintain the roller brush will help you get the longest life possible out of your belts.
Video Repair on How To Replace The Belts Hoover Windtunnel Self-Propelled;
I hope that this information was helpful to you in repairing your Hoover. If you did find this helpful, may you please rate the repair by clicking the the Thumbs Up Icons in the top right hand corner of this repair to help me start out here on Fixya? I really do appreciate it, thank you so much!
Feel free to request a repair clarification if you have any questions or concerns you'd like to address.
Chris J.
GoVacuum
Feb 22, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Canon PC941
dear friend:you must check the following:-1is there a power in the wall outlet(try any equipment from the same source of power if it is ok try to chang power cord .2-if it is not working yet try to spray on power switch many times with contact cleaner{{from radio shack}}.3-open the front cover and close it firmly to confirm that door switch is working probably{better to do this as first thing}}
my best regards.
Feb 22, 2008 | Canon PC-940 Black and White Copier
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
