Question about Garden
Countax fault codes
My countax mower keeps showing code 200 on display. New battery, but no spark? What's happening?
3 Suggested Answers
  • 246 Answers
SOURCE: I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
SOURCE: my countax mower c300 keeps
hi, my countax k18 is needed for this season for my buisness, after about 10 or so minuits it cuts out on me, no deck attached And i havnt engaged or disengaged anything... any ideas?? its defo electric as it cuts out really quick....
Posted on Feb 19, 2012
Where can I get a workshop manual for a Countax lawn mower/garden tractor?
I wish I could post the address to your mower, but there is not enough information. Start here:
Countax Tractors
or
https://support.ariens-uk.com/support/home
Dec 28, 2015 | Garden
How do I adjust the throttle/speed on my countax C800 ride on Mower
Making a throttle adjustment for the mower - YouTube
? 23:51
https://www.youtube.com/watch?v=gt0Tmo1p9cM
Apr 8, 2012 - Uploaded by VeeTheAmazingGreek
My old mower was all over the place when running. It would idlehigh then low. I came up with a way to ...Missing: countax ‎c800
[PDF]C SERIES - Pdfstream.manualsonline.com
Nov 23, 2015 | Garden
Countax d 1850 keeps stoping
Check your battery connections also check to see if the fuel line has been partly closed if none of this is the problem check your gas filter
Apr 12, 2014 | Garden
My countax 300 will not start there is nothing wrong with the battery
First check the safety switch under seat is working by bridging the gap.
Try the same with the safety switch on hand brake.
Check fuse hasn't blown.
Check spark plug is intact and cable is correctly fitted.
Check in line fuel filter.
Ensure battery is fully charged, a drop in output will result in not starting.
Hope this resolves the problem.
Gareth
Aug 02, 2013 | Yard Machines Garden
Countax
The spark plug gap need to be set or replace.
Jun 19, 2013 | Garden
My countax mower c300 keeps blowing the p c b board
Mar 25, 2011 | Garden
The sweeper shaft on my countax lawnmower keeps pulling to the left and falling out out the bearing on the right anyone know how to fix this
I have a countax E36 which had the same problem. If you remove the axle of the sweeper you will most likely find the square axle damaged at the end. I ordered a new one from cyriljohnston.co.uk and had it over night €28.00 all in. When replacing it, you may need to install washers to take up the wear on the bearing eyes ! Hope it works for you
Apr 29, 2010 | Garden
I have purchased new batteries for my mobility scooter which even when fully charged will not start my scooter. I turn the key but there is nothing ,as if a flat battery . Any ideas please Trudie
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Apr 06, 2010 | Electric Mobility Mobility Electric Power...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
