I have a ignis washmachine fl 1208, the c cycle at minite 37 abnormal sound appears.
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: kenmore elite washmachine
kinked hose adjust hose so unkinked
or water pump clogged sometimes socks get past drum into water pump
water pump sends the water out
these are the main reasons the washers wont drain
couple things needed for pump removal
bucket and a couple small cups
pull water out
once low disconnect power turn the water off disconnect
you will need someone strong and a dolly
take out side the little water left in will make washer heavy
once outside tip back lay down on side angled up a little pull pump out pull debry out with needle nose pliars 2 people needed here then put pump back in done
this is self service solution
this can be done without service person
or you could call maytag
Posted on Jul 07, 2008
onthejob5130
  • 640 Answers
SOURCE: calypso washmachine
you have a flood condition,,or overfill,,we must get rid of the water it seems the pump cant do it,,also it can be tripped or make this display fl if to much suds are in unit ..press stop than cancel and it will clear...than put unit in drain,,if water doesnt drain we have a drain problem that caused the fl error..onthejob
Posted on Feb 01, 2009
I. Need. Service. Manual. For. Ignis FL 800
Try.Googling (Ignis)( FL 800)(manual) without.parens (or periods).
Aug 01, 2016 | Washing Machines
Ignis website
how i get a manual for ignis fl910 washing machine?
Jan 23, 2014 | Washing Machines
How to unlock
Hi, You can unlock a Nokia 1208 safer and easier using unlock code. An unlock code for a Nokia 1208 can be obtained from www.superunlockcodes.com/nokia-1208/rs16wp9/ at affordable cost
UNLOCKING STEPS FOR NOKIA 1208
1 - Switch on your Nokia 1208 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1208.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1208 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1208 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 1208
Oct 15, 2012 | Nokia 1208 Cellular Phone
Nokia 1208 Unlocking Instructions
Nokia 1208 Unlocking instructions:
You can get the Unlock code and instructions at Mobileunlocksolutions.com/nokia-1208/rs1wp9/ and unlock it easily.
Warning : Do not enter any wrong unlock codes on your Nokia 1208 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1208 mobile phone, your phone may get hard locked and sometimes become unusable.
May 24, 2012 | Nokia Cell Phones
How do i remove the ac condenser on a mazda 3
B3E071161450W02
1. Disconnect the negative battery cable.
2. Discharge the refrigerant. (See REFRIGERANT CHARGING.)
3. Remove the splash shield.
4. Remove the A/C drive belt. (See DRIVE BELT REPLACEMENT [LF].)
5. Detach the two wiring harness clamps.
6. Disconnect the magnetic clutch connector.
7. Remove the A/C compressor protector.
8. Disconnect the cooler hose (LO) and cooler hose (HI). Do not allow remaining compressor oil in the refrigerant line to spill. (See Refrigerant Line Removal Note.) (See Refrigerant Line Installation Note.)
Caution • If moisture or foreign material enters the refrigeration cycle, cooling ability will be lowered and abnormal noise or other malfunction could occur. Always plug open fittings immediately after removing any refrigeration cycle parts. 9. Remove the compressor protector.
10. Remove in the order indicated in the table. Do not allow remaining compressor oil in the A/C compressor to spill.
11. Install in the reverse order of removal.
12. Perform the refrigerant system performance test. (See REFRIGERANT SYSTEM PERFORMANCE TEST.)
A/C Compressor Installation Note 1. When replacing the A/C compressor, remove the following amount of compressor oil from the new A/C compressor.
Amount drained (approx. quantity) • 155 ml {155 cc, 5.24 fl oz} - [compressor oil from old A/C compressor + 15 ml {15 cc, 0.5 fl oz}]
Aug 10, 2010 | 2007 Mazda 3
Is it possible to download the user manual for the ignis washing machine model FL 1207
Sure, you can retrieve the manual form the main Ignis support website. You will need to enter your model number in the provided space. You can also, retrieve you manual at this link below as well.
Click Here
Jul 09, 2009 | Washing Machines
GOING NUTS WITH WASHER
FL Flood condition"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. You will need to unplug this unit for 5 minutes. if you continue to hear beeps and the (FL) appears once more after the shut down, you will need to replace the water level switch.
Press STOP/CANCEL to clear the display and unplug the unit for 5 minutes.
Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washmachine
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
