Philips hts3568dw 98
Hi. my rear "wireless speakers dont work. The front dongle is a solid blue light the rear just flashes. but no sound. m do you have to link them or do you need to activate the dongle? how do i get it it work?
SOURCE: No reception or sound on rear speakers.
Here's the fix: power off the sub-woofer and wait for 60 secs before powering it on again. My rear receiver works every time now.  I guess the sub-woofer isn't just a dumb speaker; it has some kind of smarts in it too.
Prior to this, I had only tried cycling power to the DVD player itself.  I also re-seated the two, fat cables connected to the junction box. One of them had worked itself slightly loose and the result was completely absent speaker channels.
Posted on Dec 29, 2007
SOURCE: Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Posted on Jul 05, 2008
SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Posted on Aug 11, 2008
SOURCE: SC-BT !00 Panasonic wireless speaker connection won't link
If you go into the set up menu and go to the speakers set up - it only shows the right, left, centre and subwoofer on the screen. You need to go down to the box below these speakers and activate the rear speakers which are not shown. The wireless section will then light up w1/2 on the display at the front of the scbt100 - i had to call panasonic to figure this out and they advised me it was missing from the instructions!!!
Posted on Mar 07, 2009
ColdTattoo
  • 219 Answers
SOURCE: No sound from rear/ surround speakers on Bose V20
Yes, very easy and cheap if you get it from the right place. Fiber Optic going from the output of the device to the input of the receiver. If your lucky enough to have an input/output fiberoptic in your tv, run the fiber from the device to the tv input, fiber the output of the tv to the receiver so not only are you getting the device full surround sound, but you'll also get better TV surround sound for those that are made with Dolby pro logic II sound. (pretty much all the newer movies and shows)
Posted on Jun 13, 2009
Radio wiring identification 98 dodge ram 1500
Car Radio Constant 12v+ Wire: Red Car Radio Switched 12v+ Wire: Red/White Car Radio Ground Wire: Chassis Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: Orange/White Car Stereo Antenna Trigger: Yellow Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: Behind the glove box. Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 21, 2016 | Jeep 94-97 98 99 00 01 Dodge Ram 1500...
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
I need to know the speaker wire codes for a 98 pontiac sunfire
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Oct 02, 2009 | 1998 Pontiac Sunfire
BUTCHERED WIRING.
Dont know what year you have but one of these will work. Ground is usually separate in Dodges:
1990 Dodge Caravan Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Right Front Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): Blue/Orange
2003 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Jun 02, 2009 | Car Audio & Video
Problem with rear speakers
hello
can sell me the junction box?
thanks
contact brilhasman@clix.pt
urgent
Jun 01, 2009 | Philips Cineos HTS9800W System
I need the wiring diagram for the radio on a 1994 nissian quest gxe
Constant 12V+ Brown/White
Switched 12V+ Orange
Ground Black/Light Green
Illumination Pink/Black
Dimmer Pink
Front Speakers 5" x 7" Doors
Left Front (+) Gray/Blue
Left Front (-) Yellow/Blue
Right Front (+) Blue
Right Front (-) Yellow
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Blue/White
Left Rear (-) Blue/White
Right Rear (+) Blue/Black
Right Rear (-) Red/Blue
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 13, 2009 | 1994 Nissan Quest
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Black/Light Blue
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Audio Front Speakers Size: 3 1/2′
Car Audio Rear Speakers Location: Rear Deck
Feb 23, 2009 | 1996 Eagle Talon
Hi!i have Philips HTS9800W but wireless rear speakers do not work!
The wireless rear speakers aren't wireless per se. They have to be connected to a receiver box and it's that box that brings in the system's wireless transmissions, eliminating in this way any cable runs from the front of the room to the back.
Nov 28, 2008 | Philips Televison & Video
37 people viewed this question
 Grubhead
Grubhead
