I own a Toshiba TW56F80 rear projection unit. I've owned it since 1997, and it has served me well. A few months ago, I heard a zap sound from inside the cabinet, and all my remote functions stopped. I can still manually turn the set on and adjust the volume, video inputs etc from the fron panel, but all the advanced features and the full convergence adjustments are no longer available. Is this worth repairing, or should I move on? I really can't afford a new plasma or other type HDTV just yet, and the picture on the Toshiba is still stunning for DVD, and HiRes sources from my media center PC.
  • 3 more comments
  • westmassboy Jun 22, 2009
    Yes. Tried that when it first happened. As I said, I hear a distinct zap from inside the set, and can only assume something shorted or burned out.
    no, just the one time
    I'll try it for sure tonight
    thanks
  • John Snow
    John Snow May 11, 2010
    Do you hear the zap every time you turn on the set?
  • John Snow
    Have you tried to unplug the set overnight and see if that resets the television?
  • 668 Answers
Sounds like to me that a HV Arc or a Static discharge has corrupted the eeprom data or caused the Main Micro Processor to lock out those features. Have you unplugged the set for 24hrs? As easy as this sounds it is true that allowing the lower voltages bleed off so the eeprom and micro are able to fully re-set themselves. I doesn't always work but if you have not tried it, try it . That would be a cheap fix. If this does not fix it, parts are going to be tough to get because of the age of the unit. Toshiba may not even manufacture them any more.
Good Luck,
Skyassoc
Posted on Jun 22, 2009
I have a Toshiba TP50G60 Rear-Projection 50" TV. It only stays on for a few seconds and then turns off. I heard this is a common problem for this type of t.v.. Is it a lost cause? If not, what should...
deesturkey,
Your unit was made in 1997. That is going on 14 years of use. While I like to fix all the TVs I can this one is probably going to keep having problems even if you solve this one. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting process and also tell you where to get any parts you need. Keep in mind though that the unit is very old for a projection TV.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 26, 2011 | Toshiba TP50G60 50" Rear Projection...
I have a 1999 plymouth breeze a few months ago
it may be a worn out boot and since you let it go so long you may now have to replace the front axle. i had that happen on a sentra i used to own
Feb 22, 2010 | 1997 Plymouth Breeze
Popping sound on my toshiba 32" flat screen
pls. cheked
1. suond ic input supplay voltage (ic B+ voltage regestance 1 ohm.
and capacetar 2200um/35v replace)
Oct 04, 2009 | Zenith R57W46 57" Rear Projection...
Buzzing sound in front of Toshiba 62HM94
Hey buddy the lamp is good hopefully havent pop yet but i suggest you dont continue powering on turn it off and call your local tech service guy the problem your having is your power supply and the balus you need to replace thats the buz noise your getting here is a local tehc athorize toshiba cecnter to help you with that in van nuys ca 818-785-8085 or go to toshiba site and get the closes to you.....
Oct 30, 2008 | Toshiba TheaterWide 62HM94 62" Rear...
Blue line shadows
sounds like convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.ht
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba
possible color wheel is faulty,call a service shop for an estimate of cost.
Dec 07, 2007 | Panasonic PT-47WX42 47" Rear Projection...
No picture
57H81 57 in. Rear Projection Television Go to above unit for tip on your problem.
Jun 22, 2007 | Toshiba 55H70 55" Rear Projection...
No picture but have sound
Toshiba 57H81 57 in. Rear Projection Television Go to above under solution for tip on fixing your problem.
Jun 22, 2007 | Toshiba TP50H50 50" Rear Projection...
No picture
95% 0f the time when this happens to a toshiba projection or regular set, the power regulator IC is bad. It is a componet that should be replaced by a service technician as there are too many points inside this set that can zap you and hurt you. If thats the only problem your talking in the range of 175 to 250 to repair this set. Good Luck
Jul 31, 2006 | Toshiba TZ43V61 43" Rear Projection...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
