Question about Mio Cyclo 300
Remove sd card reboot
How do I reboot
Sd card reboot
Remove the SD card and try again.
Dec 21, 2013 | Lands Phones
I have a Quantaray SD card reader, I put a SD card in it and it doesn't work. I guess I need a driver or software in my Windows 7
Are you sure it's an SD card? If it's larger than 2GB then it's actually an SDHC card and won't work in devices designed only for SD cards.
Aug 05, 2013 | E-Machines eMachines Desktop PC
My sd port cannot read ma sd card
Remove the SD card, reboot insert the card. Is your Card reader enabled in Device Manager? Have you done any updates? install the Card Reader driver. Toshiba Support : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Jan 17, 2013 | Toshiba C855s5214 15.6 Inch Laptop
It says please remove sd card and reboot the device
OK, this means to remove, from a PC if connected, remove any SD or Memory Cards, that maybe being used, and then to find the little reset button, (usually in little hole at side/rear) and depress it for a few seconds, and the GPS will "Reboot" and restart as usual.
Mar 12, 2011 | GPS
I was trying to upgrade the software and it wiped the comp clean can you do a reset
SYLVANIA SmartBook Operating System Update:
  1. Format an SD card 1GB or larger to FAT32
  2. Insert formated SD card into your PC
  3. Download and save the sylvania_smartbook_OS_update.zip file
  4. Unzip the sylvania_smartbook_OS_update.zip file to the root of an SD card.
  5. This should result in the creation of a folder called 'script' in the root directory of the SD card.
  6. Insert the SD card into the SmartBook (netbook) device and power on the netbook.
  7. The netbook will update its software.
  8. When completed, remove the SD card and reboot the netbook.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Sylvania G-Netbook
Phone keeps rebooting
Its simple: if rebooting occurs, just remove SD card and once booted, reinsert SD card.
Or, taking out the SIM, turn on without, turn off, and then restarting with SIM inserted again.
Apr 08, 2010 | O2 Samsung SGH-E250 Cellular Phone
Vaio won't register micro sd
Have you installed the driver for the SD card reader ? built in vaio ? check within the control panel, devices, sometimes removing the device then rebooting sorts it, press delete on the device within device manager then reboot, check it, should be back and hopefully working
Jun 14, 2009 | SanDisk 2GB microSD Memory Card
How to hard reset the htc 710
to hard reset the htc s 710....................
1) switch off the phone first,
2) again switch it on....and as soon as the green led starts blinking (indication of phone coming to life) immedietly press and hold both the soft keys at a time, and follow the instruction given on u r phone screen. :)
Jul 09, 2008 | HTC S710 Smartphone
Mio Cyclo 300 Logo
Top Mio GPS Experts
Tre Elkins
Michael Vincent Cruz
ray gallant
Are you a Mio GPS Expert? Answer questions, earn points and help others
