Question about 760Li Brief instructions f01, f02, f03. Brief
Fitting a litefx blind - 760Li Brief instructions f01, f02, f03. Brief
How do you cap off a flex copper refrigerator water line
Flex? Do you mean a braided line like this?
http://i.stack.imgur.com/9tE11.jpg
or a solid wall copper tube like this?
http://www.frankcondelli.com/staging1/store/image/cache/data/Camper/copper%20tubing%203:8-500x500.jpg
In the first case it should have a fitting on the end, usually female, for which you can buy a blind cap to screw in. See a hardware house.
In the second case you are best to sweat, or hard solder, a blind cap on the end. There are cold compression fittings using a teflon or copper olive
http://help.tradingdepot.co.uk/wp-content/uploads/2013/04/compression-nut-olive.gif
but they aren't generally recommend for terminating a pressurised line. If the line just has low pressure you could use one, and no heat is needed.
Jun 22, 2016 | Refrigerators
How do you remove vertical blinds
Vertical Blind Removal - YouTube
? 1:42
https://www.youtube.com/watch?v=DzjFN-6Ggsg
Aug 21, 2012 - Uploaded by Victory Curtains and Blinds
Vertical Blind Removal. Victory Curtains and Blinds ... How To Replace Vertical Blinds Changing Headrails ...
How to Remove and Install Vertical Blind Vanes - YouTube
? 0:44
https://www.youtube.com/watch?v=2FsauNXkRdw
Jun 10, 2013 - Uploaded by fixmyblinds
This short video will walk you through an easy way to bothremove and install the vanes on your Vertical ...
How To Replace Vertical Blinds Changing Headrails Taking ...
? 11:08
https://www.youtube.com/watch?v=XPgtms7rnQ0
Dec 15, 2015 | BrylaneHome Embossed Vertical Blinds...
When removing the top triple clamp from a93 Zzr 600 e1 how do I remove the blind bolts from the bottom of the ignition barel ? Where the wiring is located ?
They are shear bolts...the heads are designed to snap off when first fitted to make it hard to remove them for security reasons . Usual method of removal is to drill them out and replace them with cap heads.
Nov 21, 2015 | kawasaki ZZR 600 Motorcycles
Tiguan problems factory fitted extras
why not ask them, its their baby?
(bolts loose? rust, damage, cracks, we are blind here, can can list more. but why? get it serviced)
Jul 14, 2014 | Volkswagen Tiguan Cars & Trucks
Metal blind foot hem 6217c
The 6217C doesn't have a blind hem foot. You need the General Purpose (low-shank) foot, the General Purpose Needle Plate and the blind hem guide (part number 381213). The guide gets secured by the screw that holds the presser foot shank. This site, http://cart.jennys-sewing-studio.com/index.php?main_page=product_info&products_id=473 , has the blind hem guide available. This metal foot might fit your machine: http://cart.jennys-sewing-studio.com/index.php?main_page=product_info&cPath=530_73_101_164_168&products_id=463 .
I hope this helps.
(who has a similar blind hem stitch guide for my Singer Touch & Sew. I haven't gotten the hang of it yet.)
Feb 10, 2014 | Sewing Machines
How to change out a ignition switch on a 2001 altima
Hi Ceh, Remove the cowling from around the steering column by removing the screws recessed on the underside. You will need to use a cold chisel to remove the blind anti theft bolts which fasten the saddle clamp from the steering column. Once loose remove the screws holding the switch at the end of the barrel and remove the induction coil from the front (Where the key fits). Fit the new unit and re-assemble which is opposite to the work you have already carried out. When tightening the blind bolts tighten until the ends shear and break off. The new component will need to be re-programmed for the vehicle to start. Regards John
Aug 13, 2012 | 2001 Nissan Altima
How do you do a blind stitch on a Viking Fresia 415? What foot do I use?
You need a foot like this one so you can guide the folded edge of the fabric hem along against the white plastic foot. This is a generic style snap on blind hem foot, your machine should have one in the accessories that looks like this if your machine has a blind hem stitch included in its functions.
You fold the fabric into a upside down Z shape and run the top folded edge along the white guide with the fabric under the foot, hard to explain but once youve done it once, it makes sense.
You need to select the stitch on your machine that looks like 3 small zigzags, then one bigger one, or 3 straight stitches, then one zig zag to the side. This is the blind hemming stitch. You'll possibly also have a blind hemming foot to use, which helps with guiding the fabric fold into the machine and keeping it even. But if not, you should be able to buy one from your Huskqvarna dealer or a generic one from www.sewingpartsonline.com may well fit.
You'd be best served by visiting http://sewing.about.com/od/techniques/ss/machineblindsti.htm for photos and intructions if you've never done blind hem stitching before.
Blind hemming works best when hemming straight edges of fabric such as a ruffle on a full skirt - if there is any curve in the seam, it gets much harder and the result won't look so good. In essence, you press the fabric hem up, then fold the hem edge back under so you have a "S' shape, then sew along the single layer with the folded edge sitting against the foot guide. Then when the machine takes the 4th wide stitch, the needle swings to the left and catches a small stitch into the upper folded layer, then back onto the hem. The trick is adjusting the stitch so that the wide stitch doesn't show much on the right side of the garment
Sep 06, 2011 | Sewing Machines
What does the blind stitch foot look like????
If you mean a blind hem foot, you can go to www.brother-usa.com and look at their accessory catalog. It is just a presser foot that has an adjustable screw to set for an edge guide. You don't have to have a Brother any low shank blind hem foot will fit. You can order from them, 1-877-276-8437 or any online sewing machine parts place, ie. www.sewingpartsonline.com.
Jan 08, 2011 | Brother XL-2600I
Bought blind hem stitch for a 3116 singer and the needle hits it
I think you may have to make an adjustment on your blind hem foot, it also could be the wrong fit for your machine.
Mar 08, 2009 | Singer 3116 Simple
Motorola V 3
it is screwed and clockwise
Sep 23, 2007 | Motorola Mobility RAZR V3
760Li Brief instructions f01, f02, f03. Brief Logo
24 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
