Question about Car Audio & Video
Monsoon amp wire diagrams 03 grand am after market radio
  • 91 Answers
SOURCE: wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
Posted on May 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: Help installing DHD 2114 amp to Impala 03 factory radio
What car are you looking for the wiring diagram for?
A simple line level converter would convert an input signal to a factory speaker - into a useable Low Level RCA signal for your amplifier.
033d2e7.jpg There is your signal - now all you'll need from behind the radio is the 12V Remote signal.
Send me your make/model/year, and i will tell you which wire to use.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 14, 2009
  • 85 Answers
SOURCE: I have a 1996 Ford Explorer XLT V8 and I want to
You cannot wire through the jbl amps you need to go to the amp and can only wire in the speakers
Posted on Apr 01, 2010
iFixapples
  • 57 Answers
SOURCE: radio diagram
Before I post this for you, I just wanted to let you know that you can buy an aftermarket harness that plugs right into your existing harness. Then it allows you to hook up to the wires without cutting your factory wires. They might even have it at Wal-Mart for less than $15. Anyway here are the specs. Don't forget to vote if this helped you out: Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6′
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Posted on Apr 24, 2010
alicantecoli
  • 22156 Answers
SOURCE: After market radio install, but
bypass the factory amplifier you will not need it unless your deaf
Posted on Aug 21, 2010
How do i get my monsoon car stereo working again amp model # 2264744
I assume this is the one you put into your car (I answered the other question) if the radio anti theft is on you would need to get a dealer to run the serial number of the unit and get you the codes....assuming the previous didn't change it. You might come out cheaper changing the radio out with an aftermarket unit. Any unit can be used with the factory monsoon system. (I have done this in my 04 grand am monsoon). All you need is the radio of your choice and an installation kit and wiring harness adapter. You do not need the GM integration harness as long as you don't care about losing the door chime, key in ignituon chine, etc. You will need to run a switched ignition wire for the new radio as the factory one uses a data wire instead. It's just a matter of running a wire to a fuse in the drivers fuse box that comes on with the key. It's a rather easy installation and if you chose to have it done professionally should cost about $50 for labor.
Nov 12, 2016 | Cars & Trucks
How to bypass a monsoon stock amp in a 2002pontiac grand am gt
After market radio, you have to. Factory radio, you can't. you need the amp. Tell me what you are doing. I can tell you how to bypass it. You do need a volt/ ohm meter and know how to use it.
Apr 01, 2016 | Cars & Trucks
I need full complete wiring diagram for my 2001 Pontiac grand am gt Had a monsoon stock
Check the fuse first. Next replace the amp. It can be rewired at the amp. You need a volt /ohm meter to do it.
Feb 27, 2016 | Pontiac Cars & Trucks
How do I disconnect the amplifier on my 2005 Grand Prix; it makes continuous static noise whether the radio is on or off or whether the ignition is on or off?
Assuming it's the monsoon amplifier it's located under the rear deck about 8 inches away from the passenger rear speaker. However unplugging it will kill all the speakers. The only way to properly bypass it is to run all new wires.
You maybe able to find another factory amp at a salvage yard.
Warning: Most of the Monsoon head units have a 6V offset, making it incompatible with aftermarket amps.
Feb 28, 2015 | 2005 Pontiac Grand Prix
2002 saturn lw 300 radio quits
Yes it can be Amp problem,but there are many other possibilities like loose connection,radio wires getting short.
I suggest you to go through the troubleshooting help links related to car radio problems.
Click the link below:-----
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Nov 23, 2012 | 2006 Saturn Vue
1997 grand prix 4 door radio wiring diagram
Go to your local dealership repair shop. They can scan a copy for you. It will make it all very easy when you have the wire colors and circuit description.
Jul 22, 2012 | Cars & Trucks
I bought a used 2003 Jetta for my daughter with only 12,000 miles on it. The Monsoon radio suddenly stopped working. The display shows FM 88.1 (the radio staion) but there is no sound and the radio is...
I have come to find out that in the 90's auto makers started installing factory amplifiers in their cars so they could use low wattage stereos in the dash. It's usually a blue wire off the stereo that runs the amp, maybe it couldve become disconnected? I also know that even if you put in an after market stereo, this wire must be hooked up or you'll get no sound from the speakers. hope this helps.
May 26, 2009 | 2003 Volkswagen Jetta TDI
Wiring after market stereo to factory wiring equipt with factory amp
May 05, 2009 | 2001 Pontiac Grand Am SE
Radio Wiring Diagram
Go to www.crutchfield.com.
On the bottom of the page there is a link for product support. On the next page, type "2005 Grand Prix" in the search box and hit enter. The top link shows an image and pinout on models with Monsoon sound systems, the second link for ones without.
Hope that helps! Good luck!
Jun 13, 2008 | 2005 Pontiac Grand Prix
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
