Our big screen has a problem with the color.....the colors don't come together....there is color "shadows" any suggestions
  • 258 Answers
Looks like bad reception check your aerial lead at the back of tv, give it a wiggle, could be a loose aerial lead or its falling apart, check connection at wall too
Posted on Jun 22, 2009
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
Ws-65611 color shadows
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
Aug 21, 2012 | Mitsubishi WS-65611 65" Rear Projection...
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
I have a 52" Toshiba
If the picture looks like 3D and letters ,people have colors shadow over them ,Then you need to replace Both of the STK ICs they are big black ICs and will have PN# on them STK392-110 use 120s and check the 3 1.8ohms 1watt resistors.
Mats Electronics has ICs 1-800-628-1118
Nov 24, 2010 | Televison & Video
Dark shadow about 4'' at top of screen of 56'' dlp samsung hlr5667
There is a piece connected to the color wheel assembly called a light tunnel. It is between the color wheel and optic assembly. There is 4 mirrors inside. One of them probably got dislodged when the wheel shattered. Sometimes they can be repaired using high temp glue or you may have to replace the tunnel.
May 18, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Kp-46wt500 shadow and slanted images with rainbow colors
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
Rca big screen model p52939
If you cannot get a good convergence then the convergence modules need replacing.
Jun 20, 2017 | RCA P52939 52" Rear Projection Television
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Diagonal Shadow
Often a piece of foam, debris or such can get in between the lamp and color wheel which can cause the symptom your describeing.
Mar 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Hitachi Big Screen TV 46 inch Problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Sep 06, 2007 | Hitachi 46BX01B 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
