Question about ASUS Computers & Internet
"download master" "disk full" - ASUS Computers & Internet
MFP-05333449
Master Reset?
Meaning?
A) Master Password:
Laptop is taken down to nearest authorized agent, (Dealer or Repair Shop), and a Master Password is asked for.
You need to bring;
1) Form of Identification
2) Receipt for purchase of laptop
3) Credit Card or Debit Card
Authorized agent contacts laptop manufacturer.
Once the laptop manufacturer checks out whether the laptop is stolen, or not, (By their records), and receiving copy of ID, copy of purchase receipt, and fee, they will grant a Master Password.
The authorized agent then uses the master password, and sets another password of your choice, or No password if you choose.
The master password is Not given out.
B) Master reset being, reset the laptop back to the way it was, Day 1 from the factory.
Use the Restoration Disk, (CD)
When asked perform a Full Install.
Also known as Destructive Installation.
ALL personal records stored will be Gone.
1) No photos,
2) No videos,
3) No personal documents you have created, or downloaded,
4) No programs you have physically installed, or downloaded.
NOTHING is saved past Day 1 from the factory.
C) Windows installation disk:
Use the same Windows operating system, (i.e., Windows XP, Windows Vista, Windows 7, etc), from a NEW genuine copy of Windows.
Go into the BIOS Setup (utility), and in Boot Options, set the first boot device to CDROM.
This way the laptop will boot from the Windows CD.
"Master reset is a term used to describe the process of restoring an electronic device's FACTORY settings."
Have no clue what MFP - 05333449 is.
The laptop Model Number, (Product Number for HP), is on the Bottom of the laptop. (Or Netbook)
[ For example HP has a white Service Tag on the bottom.
P/N = Product Number ]
Post back in a Comment.
Regards,
joecoolvette
Apr 17, 2012 | Computers & Internet
How change prymari device?
You can either look into this online manual or follow the instructions given below.
http://support.dell.com/support/edocs/systems/dim4700/en/om/Y69490LRs.pdf
In the case of loading a particular Operating System(OS) from a specific Hard Disk, you can change the boot priority from BIOS (Hope you know to get into BIOS) as shown in the picture
Or if you want to change the physical configuration of your Hard Disks to Master and Slave, then follow these steps.
  1. Open up the side panel of your PC Case.
  2. Disconnect all the wires from both Hard disks.
  3. Look over the labelled top part of each hard disk to know the settings of JUMPER PIN so as to set it as primary(master) or secondary(slave). Please note that if you are using IDE hard disk, this may be enough. But in the case of SATA, inspite of this, you may also require to install RAID Driver after connecting them back into the computer. These drivers can be downloaded from http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection (You may require to set up your product manually and download Serial ATA drivers)
  4. (Connect them back, Screw up- if you haven't done it already). Now you may be able to use the required hard disks as primary(master) and secondary(slave).
You can also watch two videos of changing jumper of the hard disk. But be careful while replacing jumper. Any incorrect configuration or jumper setting or damage of pin may cause in device failure or result in damage of your hard disks.If you have any further doubts, feel free to ask me...
Jan 07, 2012 | Dell Dimension 4700 PC Desktop
I have a dell inspiron 1300 laptop with service tag: #CBWBD2J-595B and i need system/bios password for it.Any help is appreciated?
To unlock your laptop using the easiest method available go to: http://dell-inspiron-1300-bios-password.biospwd.com
Dell password authentication system explained :
The BIOS of most modern computers also allow a password to be set for each of the connected hard drives. This password is stored in the service area of the hard disk. Because of this, moving the password protected hard drive to a new computer does not allow access to the hard drive unless the password that was assigned to the hard drive is provided.
The ATA Security Mode Feature Set that is implemented in all modern hard drives actually provides for two passwords, a "Master Password" and a "User Password"
The User Password locks the hard drive and the Master Password is only used to allow an administrator to reset the user password.
The BIOS of many computers will not allow the master password for the hard drive to be changed from the default, so they rarely are. A quick search of Google.com for the specific model of hard drive with the phrase "ATA Master Password" will generally result in multiple web pages that contain the default master password . Hardware tools can recover, reset, or brute-force both the User and Master Passwords.
Full Disk Encryption Methods:
There are two major categories of full disk encryption (FDE)-software-based and hardware-based. Software-based encryption modifies the hard drive drivers and uses the CPU to encrypt all data as it is written to the drive and decrypt all data read from the hard drive. Hardware-based full disk encryption is built into the hard drive and is totally transparent to the user and does not impose a performance impact on the computer.
Software-Based Full Disk Encryption
Wikipedia maintains a lengthy list of disk encryption software The two most popular FDE software implementations are TrueCrypt and BitLocker. BitLocker is included as a feature in the Ultimate and Enterprise editions of Microsoft Windows Vista and Windows 7, but has to be enabled and configured to provide protection. TrueCrypt [18] is free open source software that is ideal for individual users, but lacks management features that make it attractive to enterprise-wide deployment.
Deployment of software-based full disk encryption in any organization with more than just a few computers requires careful consideration of how the encryption keys will be managed. Great encryption without proper key management is like locking the doors to your house and leaving the key under your doormat. One study on the usage of encryption states that 54 percent of respondents had experienced either stolen or unaccounted for encryption keys and that 78 percent experienced system downtime due to encryption failures in the past twelve months [20]. Full Disk Encryption solutions that are targeted at the enterprise typically offer integration with Microsoft's Active Directory or other LDAP directories for secure key management.
In 2008, security researchers created shockwaves by publishing a paper called Lest We Remember: Cold Boot Attacks on Encryption Keys [21]. This paper, and the accompanying YouTube video demonstrate how Software-Based FDE can be circumvented by rebooting a computer that has been left in a locked-screen or sleep state. The attack exploits the fact that Dynamic Random Access Memory
Jan 14, 2011 | Dell Inspiron 6400 Notebook
2nd hard drive on Dell Dimension 8300 ( both ATA)
setup the original harddrive as master and the new one as slave then the drive that comes up as c will be the master and the others will follow suit and when you install the games just change it in the install
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Western Digital Caviar SE16 WD5000AAKB -...
Olympus D550 I'm missing my master 2 download disk don't seem to
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
May 06, 2009 | Olympus Camedia D-550 Zoom Digital Camera
Lost my install disk for my computer how can i download one
For Windows:
For MAC:
Apr 16, 2009 | Olympus Stylus 710 Digital Camera
I forgot the password for my motherboard dell inspiron 1100 is there a way to bypass it or crack it
To unlock your laptop using the easiest method available go to: http://dell-inspiron-1100-bios-password.biospwd.com
Apr 11, 2009 | Dell Inspiron 1000 Notebook
Need to download disk, but cannot find serial #'s
For Windows:
For MAC:
Since it is a free download there is no serial key required.
Apr 01, 2009 | Olympus Stylus 720 SW Digital Camera
Hard drive is full
Aquire disk imaging program such as norton ghost. Install 2nd, larger HDD into existing computer. Boot computer using ghost boot disk. "Image" existing HDD to newer, larger HDD.
Remove existing HDD. Set 'new' HDD to proper position (Master, etc).
Boot computer.
Joy.
Feb 19, 2009 | Microsoft Windows XP Professional
Packard bell win 98
You need a floppy windows startup disk.
Nov 08, 2007 | Packard Bell Packard-Bell Full Page...
Computers & Internet Logo
186 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
