Question about Toto Aquia II Dual Flush Toilet
Inlet valve blocked - Toto Aquia II Dual Flush Toilet
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
How to fix the washer "f" notification?
If doesnt drain the water first, then the pump outlet filter is blocked
Dec 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Ice maker is not getting water to make ice
Hello there,
When your ice maker is not getting water into it, it simply means the water inlet valve is clooged with dirt and have blocked the valve from getting water into the ice maker.
Your icemaker's water inlet valve could be filled with ice. If it is, simply thaw the its water tube with a hair dryer to remove the blockage. Be careful to not melt any plastic parts with the blow dryer. An icemaker's water inlet valve has a filtering screen to block minerals and other debris from entering into your ice cubes. It is possible that the water inlet valve's screen is blocked, and not allowing any water through to make ice. Clean out any built up debris you find. You should be able to pop the screen out of place with a screwdriver and then put it back in place with the screwdriver again once it is cleaned.
Alternatively, the water inlet valve itself may have become defective. You will have to test it. If the test proves the valve is defective, replace it.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Icemaker not making ice
Hi
Please check the water inlet valve, it might be frozen or blocked with mineral deposit. Use a hair dryer to remove the blockage. Make sure the water inlet valve's screen is not blocked. If the issue persists, then the water inlet valve has gone bad, use a multimeter to test the water inlet valve's continuity. Use a multimeter to test the continuity. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Maytag Refrigerators
Have small commercial kenmore ice maker-model 106 89583700. Replaced pump-now no ice is forming. Cleaning light stays on-won't go off. Any suggestions?
Water Inlet Valve
if you need more info post it and I'll see if I can locate more
please take a moment to rate my response
May 31, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Where on the unit are the inlet valve and the push button valve?
On the front of the pump unit is a large aluminum block, the valves are inside that. The inlet valve is behind the fitting for the suction tube and the push button valve is the only one on the bottom of the block.
Dec 17, 2010 | Campbell Hausfeld Airless Spray Guns &...
Icemaker is not making ice
Investigate each of these two areas if your icemaker is not making ice :
Water Inlet Valve
* How to test an icemaker's water inlet valve.
Defrost Thermostat
It could just be that your freezer thermostat is not set low enough. Try adjusting the thermostat to a colder setting.
Or your icemaker might not be making ice because of a defective defrost thermostat. Test your defrost thermostat to determine if it has malfunctioned. If it has, you will need to replace it.
Keep us updated and remember to rate this answer. Good luck.
Sep 30, 2010 | GE Refrigerators
My washer only get a little water and my clothes dont get clean
could be blocked inlet hose/filter/connection. If water flow is ok to inlet valve on rear of machine, it's probably a faulty inlet valve. Replace valve with new unit......Good luck....Nomess
May 14, 2010 | Washing Machines
When starting a new cycle no water fills in. It just makes a buzzing sound
An inlet valve can buzz normally...However, if water is not flowing it probably means that the inlet valve is faulty..Make sure that the filters on the inlet valve are not blocked..If they are clear it's probably a faulty valve... Good Luck....Nomess
May 13, 2010 | Washing Machines
I have a KA fridge with ice maker. the ice maker cycles but does not fill with water. have changed the inlet valve but no change. any ideas what to do next
See if the water inlet valve is stopped up with ice, blocking the water. This happens when the water inlet valve leaks.
Sep 12, 2009 | Refrigerators
Toto Aquia II Dual Flush Toilet Logo
53 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
