Question about Ricoh Aficio Mp C2500 Color Laser - Printer / Copier / Scanner
Where is the transfer belt contact sensor located?
I need to clean the sensor to clear the error code sc 442.
4 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Posted on Oct 27, 2008
M2Tech1
  • 313 Answers
SOURCE: code sc 305
you could try and reset in service mode yourself.. try this press the yellow clear button above the number pad then enter 107 then hold down the stop button for about 5 secs .. the screen will change then turn off the machine and wait 5 secs turn back on.. Im not sure why you are getting teh code 305 as this machine doesnt have a corona wire cleaner.. is the code correct?.. good luck
Posted on Jul 30, 2009
SOURCE: REPLACED TRANSFER BELT; CLEARED TRANSFER
problem solved by replacing NVRAM on BCU.
thank you for your reply
Posted on Dec 05, 2009
I am getting error code sc 477 on my Ricoh Pro C901...any ideas?
Image transfer belt overrun sensor (rear) - these can become sticky as they are above the fuser - to clear the error physically move the belt towards the front of the machine away from the sensor. line up with black lines on bed of intermediate transfer blades' assembly make sure all rollers are clean and located correctly it is ok to turn the belt around to see if that helps
Apr 21, 2017 | Ricoh Office Equipment & Supplies
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
May 19, 2014 | Ricoh Intermediate Transfer Belt Unit for...
Open right door.
Density sensors (5) are located above the transfer belt behind the black plastic cover. Use a damp rag to clean. If you are trying to clear SC400 code, you will also need to pull out the transfer belt assy enough to take off the silver plate that is on that end of the assembly and clean it too. Toner builds up on the silver plate.
May 06, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
What is meant by error code SC 403 of RICHO AFICIO 2035E
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Jan 20, 2010 | Ricoh Aficio 2035 Copier
Customer has an Sc-405 code. They reset it by turning off machine then on. The machine only works for part of day then go's back into sc-405 code again.
that is a transfer belt error. transfer belt not moving away from the drum during ID sensor pattern check.possible main motor/ drive malfunction, trans. belt position sensor problem.
Nov 05, 2009 | Ricoh Aficio 450 Copier
Error message 457 on my ricoh af4106 copier
Hi!
This information might help you.
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803- 012)
4. Replace the belt cleaning shift clutch. (Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Sep 19, 2009 | Office Equipment & Supplies
SC 400
Hello sir; The error code you post out, it's means "transfer belt bias problem" that you have go to high voltage board ,I/O board or main board, before we go, why don't try make a reset;
1, press "clear mode" key, then enter 107 then press and hold down "clear/stop"..
2, turn power off and on.
Jan 11, 2009 | Ricoh Aficio 450 Copier
Getting "service code 442" on startup
SC442 Transfer belt contact error The transfer belt contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates. • Dirty transfer belt contact sensor • Defective transfer belt contact motor • Disconnected connector of transfer belt contact sensor or motor • Disconnected cable 1. Replace the transfer belt contact sensor. 2. Replace the transfer belt contact motor
Apr 01, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
the image
transfer belt’s
cleaning unit
section touches the
signal remains LOW.
remains HIGH.
• Dirty Sensor
• Defective sensor
shift clutch
• Defective drum
motor
board
board
belt unit.
H.P. sensor.
012)
motor.
[Signal Check]
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio Mp C2500 Color Laser - Printer / Copier / Scanner Logo
93 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
