Question about Whirlpool Ovens
Why won't my whirlpool double oven model# GBD 307 cut off, plus getting a F2 E0 error code
My whirlpool oven model gbd 307 will not cut off, when I press the cancel key. Also, the oven will get to 350 degrees and cut off making a beeping sound, then the oven gives off error code F2 E0
  • Whirlpool Master
  • 5,323 Answers
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
why won't my whirlpool double oven model# GBD 307  - 24346158-rlcwkvmjohmhoaex2htic0pp-3-0.jpg
24346158-rlcwkvmjohmhoaex2htic0pp-3-2.jpg why won't my whirlpool double oven model# GBD 307 - 24346158-rlcwkvmjohmhoaex2htic0pp-3-5.jpgt/uploads/images/24346158-rlcwkvmjohmhoaex2htic0pp-3-5.jpg" alt="24346158why won't my whirlpool double oven model# GBD 307 - 24346158-rlcwkvmjohmhoaex2htic0pp-3-9.jpg"h_mi" />
Posted on May 18, 2015
2 Suggested Answers
SOURCE: My Whirlpool convection oven model GBD 307 has a
I called a repair man to come out and fix it.
Posted on Oct 07, 2009
Whirlpool electric double wall oven error code E2F6
Good Morning!
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Mar 22, 2017 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
Feb 20, 2017 | Whirlpool Ovens
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty. http://blog.fixyourboard.com/2015/08/20/gbd-rbd-whirlpool-oven-problems-causes-and-solutions/
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
I have a whirlpool double oven mod GBD 307PDS10. I have just replaced the control board. It was working fine for about 30 minutes and I had the clock set and it was good to go, But now the clock button...
Try removing the ribbon connector and cleaning the end that plugs into the microcomputer. You can rub it lightly with an eraser or use electrical contact cleaner on it.
Jan 13, 2011 | Whirlpool GBD307PDS Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
93 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
