Question about Air Tools & Compressors
COMP SURGES ENGINE DOES NOT
DO NOT KNOW AGE BUT UNIT SEVERLY ABUSED
  • 331 Answers
Ok I need the model and manufacture. What engine does it have?
Posted on Jun 22, 2009
Briggs 19E412, the engine surges from full open throtle to closed, runs best when choke is paritally closed but still surges
comp air wont do it.. soak in carb cleaner to make sure all orifices are clear.. use fishing line to clear them out THEN comp air
Sep 06, 2014 | Motorcycles
My 1992 chevy g20 van surges and i'm not sure exactly why. I changed the pcv valve, fuel filter, spark plugs, and air filter. What are some possibilities
My first thought would be a vacuum leak in one of the hoses. Rubber hoses get brittle with age and even a small crack in a hose may cause surging. Happened to me in a Lumina.
Apr 26, 2012 | 1997 Chevrolet Astro
My 10 year old Marantz SR-14 EX used to work perfectly, but has just decided to not turn on. Never abused, no water damage, just no power. The unswitched plug works, but not the switched plug. Any easy...
It's probably just an age issue. Capacitors in the power supply can dry out and not charge properly, and that would be a good place to start looking for problems. Sometimes you can see obvious signs of failure, like bulgy or split tops. Other times the only way to tell is by measuring the part's value. Another common problem is rectifier diodes that break down and short, or may have been damaged by power line surges. They cause the line fuse to blow when they fail, so if you find a blown fuse this may be why. Most shops have a small charge to check over a receiver, and it might be worth paying to have this looked at. Then you can make your decision.
Jan 08, 2011 | Marantz SR-14EX 5.1 Channels Receiver
Car is idling fine; however, when the accelerator is applied, it surges, and if the car is put in gear, it surges so severly that there is little power
it is either a failed injector, injector with loose wire/connector, fouled sparkplug, worn HT lead or the temp sender on the engine - hyundai charge a fair bit for testing and the temp sender is usually only £27.00 at (local cheap) motor parts shop
Bit tired to explain at moment... watch this space... yawn Long day!
Jan 15, 2010 | 2001 Hyundai Santa Fe
The freezer fan surges, it sounds like it actually is cutting off and starts back up immediately. It does this occasionally, not all the time. The unit is 4 years old.
Your unit is being controled by the prossser . and both fans and the comp. will run at different speeds . they are d c and voltage controled. low /med/high/ sensors tell p c control what to do . . this sounds like a normal frig .. hope this helped/ pls leave feed back mm
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
AIR PRESSURE SURGES ENGINE DOES NOT
you have a compression leak most likly around a seal that is trying to still do its job
Jun 22, 2009 | Air Tools & Compressors
Transmission surges engine light on,car is not abused,only has 81,000
You need to see what code is causing the check engine light to come on.
Also check the big black air intake tube from the air filter box to the throttle body and make sure it both sides are on all the way and clamps tight. If its loose it will pull away from the throttle body on acceleration causing surging and possibly a lean code.
Apr 03, 2009 | 2007 Toyota Camry
S10 blazer surges
might wanna check intake gasket for leaks on the high engine rev as for tranny might be in the comp
Dec 05, 2008 | 1994 Chevrolet S-10
Mazda b2200 compression specs
those are average numbers and they are a little on the low but that is typical considering the age of the vehicle the compression should be 115 -120 psi.. hope this helps please rate this...thanks
Sep 24, 2008 | 1988 Mazda B2200
CAN' READ PLATE ON A/C - CAN'T TELL TONNAGE
that comp is a 25k btu depending on the age of the unit it is a 2 ton or 2 1/2
Aug 10, 2008 | Ruud UAKA030 Air Conditioner
Air Tools & Compressors Logo
23 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
