Question about Ricoh Aficio Mp C2500 Color Laser - Printer / Copier / Scanner
Where is the transfer belt contact sensor located?
I need to clean the sensor to clear the error code.
    Habit-Forming:
    Scholar:
  • Ricoh Expert
  • 129 Answers
Open right door.
Density sensors (5) are located above the transfer belt behind the black plastic cover. Use a damp rag to clean. If you are trying to clear SC400 code, you will also need to pull out the transfer belt assy enough to take off the silver plate that is on that end of the assembly and clean it too. Toner builds up on the silver plate.
Posted on May 18, 2014
I am getting error code sc 477 on my Ricoh Pro C901...any ideas?
Image transfer belt overrun sensor (rear) - these can become sticky as they are above the fuser - to clear the error physically move the belt towards the front of the machine away from the sensor. line up with black lines on bed of intermediate transfer blades' assembly make sure all rollers are clean and located correctly it is ok to turn the belt around to see if that helps
Apr 21, 2017 | Ricoh Office Equipment & Supplies
Hi I have a Konica Minolta C-550 I appear P. -21 code After I changed the UNIT appeared to me Code P. -5 What should I do
I am going to assume you replaced the Transfer belt and transfer roller. Since you did not state that in your input. You did replace both at the same time. Cleared the counter for the transfer roller in the service mode?. Anyway the code P-5 and P-21 have to do with the registration sensor located below the transfer belt. On the right side of the machine. Where the edge of the belt is and exposed below the belt and behind the large plastic part below the belt there are two sensors one to the front the other to the rear of the belt, again below the belt assembly. It will require you the expose the sensors clean them. Worse case have them replaced, or the Main board!!!!. Recommend you have a Konica Minolta tech come out and do this procedure. P-5 is the front sensor failure
Apr 05, 2015 | Konica Minolta Office Equipment & Supplies
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
May 19, 2014 | Ricoh Intermediate Transfer Belt Unit for...
Ricoh sc452
That error code is related to Paper transfer belt contact motor error
The paper transfer belt contact motor drives beyond the specified time during home position detection or contact operation.Broken harness or defective connectors. Disconnected connector of paper transfer belt contact sensor or motor. Defective paper transfer belt contact motor. Paper transfer belt unit not installed try to change the motor
Oct 24, 2013 | Office Equipment & Supplies
How to solve error SC471 on my Ricoh alficio cl7000
This is a transferbelt home position error.
Book says:
1. Turn the main switch off and on.
2. Reset the transfer belt unit.
3. Clean or replace the transfer belt
sensor.
4. Replace the transfer belt contact
motor.
5. Check the contact and release
mechanism of the transfer belt unit.
My guess is cleaning will solve it.
open the front door and sing don the green lever
locate the 2 screws at the top and bottom of the unit and remove them.
remove the cleaning unit 1 screw and a thmb lever slide the unit out (its on rails) wipevacum and/or blow clean the unit and re assemble
also clean the connector that it plugs to in the back of the machine
(q-tip)
if it still appears belt or unit will need to be replaced
Apr 04, 2010 | Ricoh Aficio CL7000 Laser Printer
What is meant by error code SC 403 of RICHO AFICIO 2035E
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Jan 20, 2010 | Ricoh Aficio 2035 Copier
Have error code sc457 on copier, have received detailed instructions on how to fix it, but I need to know how to open it?
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
Sep 20, 2009 | Office Equipment & Supplies
Error message 457 on my ricoh af4106 copier
Hi!
This information might help you.
• Dirty Sensor
• Defective sensor
belt unit.
3. Replace the sensor. (Input Check: 5-803- 012)
4. Replace the belt cleaning shift clutch. (Output Check: SP5-804-036)
control board
Sep 19, 2009 | Office Equipment & Supplies
Getting "service code 442" on startup
SC442 Transfer belt contact error The transfer belt contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates. • Dirty transfer belt contact sensor • Defective transfer belt contact motor • Disconnected connector of transfer belt contact sensor or motor • Disconnected cable 1. Replace the transfer belt contact sensor. 2. Replace the transfer belt contact motor
Apr 01, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio Mp C2500 Color Laser - Printer / Copier / Scanner Logo
277 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
