Question about Philips Vacuums
Philips v acuum switches off aftaer 10 seconds new bag new filters new everything any answers
Philips vacuum switches off after 10 seconds. I bought new filters new bags and it does the same any ideas fc9073 make
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Fuse issue to be sure.
Posted on May 06, 2014
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
  • 13 Answers
SOURCE: Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Posted on Oct 03, 2008
  • 430 Answers
SOURCE: with a new bag -after turning vacuum on, it shuts down
This vac is prone to a control valve failure with the exact symptoms you describe. There is a dial valve on top of the machine designed to regulate how full the bag will get. The valve which sits underneath the dial on the vac likely has a broken plunger and will need to be replaced. Take it to an AERUS Electrolux dealer / shop for an experienced tech to work on.
Posted on Sep 14, 2009
  • 389 Answers
SOURCE: Sebo x1.1 fitted with new bag and filter but red
Without doubt this indicates that there's a blockage somewhere. The two easiest places to look are: 1. on the underside of the machine there's an inspection flap - check in there; 2. remove the flexible hose completely from the machine at both ends - check in the hose itself, and where it enters the machine near the handle .  The only other place to look is where the base connects to the bag compartment - to check there, you need to separate those two parts by pressing the button at bottom front of bag compartment and pulling the base away (this can be difficult - four hands would be useful - but once you're pressing that button, nothing else other than friction is holding the parts together). Once the parts are separated, check every orifice you can see (the parts just push back together again).
I think that covers it.  Good luck, and please remember to rate this response.
Posted on Sep 26, 2009
  • 694 Answers
SOURCE: my vacuum stops showing "bag full" even after I
This is most probably due to a worn out or clogged Control Valve Assembly.
Detach the hose and see if it runs. If it does, place hand over hole. If it shuts off, CVA is probably the cause. A clogged CVA is generally due to using generic/made-to-fit bags. Genuine bags have "Home Solutions" printed on them.
You can try turning the dial all the way to the large dot, then try to run the vacuum.
If it is the CVA, you'll need to take it to an authorized Aerus Electrolux store and have their service tech repair or replace the part. I recommend a service and clean of the vacuum at the same time. This will extend the life of the vacuum.
Posted on Nov 21, 2010
Testimonial: "Super reply! Thanks for specific info. I detached the hose and (dang it) had the same problem. The bags are genuine, so it looks like a dealer repair."
Evrything is clean or new. bag filters hepa ect. the problem is i plug it in , it fires to life straight away without the customary flashing green lights and lift of the vacume handle , then runs for
Not knowing what kind of vacuum and not having enough details for a definitive answer it seems you may have an obstruction somewhere that is restricting the airflow. Sometimes they can be very difficult to locate. Start where the dirt collects, in the bag or dirt cup depending on what vacuum you have and work your way through the vacuum trying to locate a clog or obstruction.
Jan 14, 2015 | Vacuums
Vacuum won't turn on
change the switch this is very common the switches go out and that is the only thing wrong with it causing it not to get power
Mar 20, 2014 | Generic Taski 8500 600 Bora / Baby Bora...
Baby bora won't turn on
check the windings if they are not broke replace the switch for it is broken
Euro-pro EP57 vacuum bags
Call
EURO-PRO Customer Service at: 800-798-7398
514-842-8691
or Fax to: 514-842-6985
Monday to Friday 8:30 AM - 5:00 PM Eastern Standard Time
Replacement set of 2 Cloth Bags and 2 sets of Filters: $10.95 + $3.95 Shipping & Handling
Replacement set of 10 Paper Bags and 2 sets of Filters: $ 9.95 + $3.95 Shipping & Handling
Jan 30, 2013 | Euro-Pro EP055 Bagged Canister Vacuum
I bought it in may , I can honestly say , it is THE worst vaccum
There are several filters on bag-less vacuums that need to be cleaned. Dig out your owners manual or open the one below. See section 3 for filters and maintenance. If you are vacuuming a house bigger than about 1500 square feet, you should be cleaning the filters every other use. Personally, after using a bagless for a couple of months, I went back to my bagged vacuum.
http://www.hoover.com/pdfs/manuals/U6630900.pdf
Dec 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
The Intelliclean function isn't working properly. The indicators illuminate when I switch Intelliclean off, then on again, but the indicators are not changing (nor the power level) when I vacuum dirty...
I was having the same problem with my Intelliclean and I read somewhere on the internet that I should undo the bag, clean in the area where the bag attached to vacuum. When I took bag off, something was stuck there and after I removed it, everything worked fine. I think you need to clean the sensor and check your bag.
Dec 16, 2009 | Kenmore 31913 Progressive Direct Drive...
Where do i put the trash bag in the machine?
I have access to the service manual for this machine if it will help you.
Dec 03, 2009 | Philips Vacuums
Mine wont pick up
filters are internal and if blocked will affect air flow. Check brushes in the foot not jammed or wrapped in hair
Sep 13, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
Top Philips Vacuums Experts
Jim Parker
Jim Parker
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
