How to get PC back where it was before failed System Restore Windows 7 in regular mode?
Attempted System Restore - failed When restarted got preparing desktop for long time When it started, the wallpaper/screensaver was one I've never seen before and lots of content has vanished. Start in Safe Mode and all content is there. H E L P !
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
Well then... I would start it in safe mode and do system restore, unless you want to continuously operate in safe mode...
Posted on Jun 02, 2014
Clockwire
  • 72 Answers
SOURCE: safe mode
Hi there, Try tapping F8 on boot to access the boot menu select "start windows normal". if it will not let you boot in to safemode with cmd promt and run "chkdsk /f" to check for bad sectors and repair othere HD issues. Also try "Last known Configuration" as a last ditch effort before moving on to System restore. IF system restore options fail to work let me know and we can do a system restore and restore your system to an earlier time through the cmd prompt. Good luck and i hope this helps
Posted on Dec 07, 2008
kinerf
  • 27 Answers
SOURCE: acer aspire one stuck on windows safe mode restart
If you have the option of going to a command prompt (on the choose how to start "text" screen), do it, and type at the C:> fdisk /mbr then press the ENTER key. This may fix things. Also, try removing the battery when the computer is off, wait about a minute, then replace it and start computer. This actually helps sometimes.
Posted on Sep 07, 2009
SOURCE: Asus Eee PC 1005HA - Windows won't Start
i have the exact same problem. those solutions cannot help me. i dont have any hardware installed or anything plugged into it besides the power cord. also it doesnt have a cd drive so i cant put that xp cd you were talking about. what else can we do to solve this problem. i cant get past that screen to do any of these solutions. please help
Posted on Feb 14, 2010
  • 266 Answers
SOURCE: How to get it to start in safe mode to do a system restore
Restart your pc and press F8 key. then you will get SAFE mode option
Posted on Feb 15, 2010
Geekman
  • 32281 Answers
SOURCE: Acer Aspire 5315-2713 Windows XP Boot fails, Safe
If the BIOS does not detect the hard drive, the computer won't boot up because the Windows operating system is on the hard disk.
Try re-seating the hard drive to make sure it makes proper connection, when you boot up again and the hard drive is not detected then most likely the hard drive has failed.
To get the Acer operating again, replace the hard drive, install Windows and the Acer device drivers plus your programs.
Normal 0
You can download the drivers from the Acer WEB site using a different computer and then install them on your notebook. Make sure you select the model of your laptop and the XP or Vista version of the drivers you that require and it matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Posted on Oct 13, 2010
Medion problems
Hi
Run a chkdsk from the command prompt, once you have done this see if you can get on in safe mode and then restore it to a time before the update attempted to install
Cliff C
Aug 23, 2014 | Medion Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
How to get PC back normal in regular mode after System Restore failure?
What is the configuration to your system. At least 1.9Ghz CPU, at least 1 GB memory and at about 25GB hard disc space is necessary to run Win-7 flawless. Otherwise, the system will hang after loading O/S, when it restarts. Gopakumar Gopalan Google If your system has these configurations, re-load the O/S and check.
May 06, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I have a Toshiba satellite L755-s5153 when I turn it on it says "windows failed to start. A recent hardware or software change might be the cause. to fix the problem:" but I don't have the original disk...
Starting Windows 7 in Safe Mode is an excellent next step when starting Windows normally is not possible. Safe Mode only starts the most important Windows 7 processes so, depending on the problem you're having, you might be able to troubleshoot or even fix the problem from here.
To begin entering Windows 7 Safe Mode, turn on or restart your PC.
Just before the Windows 7 splash screen shown above appears, press the F8 key to enterAdvanced Boot Options.
Next you can restore your system from a previous known working date from your restore function. If you are using Windows 7 you may follow these step to restore.
1. Start
2. Go to "All Programs"
3. Select "Accessories"
4. Select "System Tools"
5. Select "System Restore"
Do hope this helps.
Oct 16, 2013 | Toshiba L755-S5153 15.6" Laptop
Windows xp contineous reboot after installation of Avira antivirus
You might have other issues other than antivirus ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then uninstall Anvira then you might restart to see if the problem is resolved if not start in safe mode again
Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps
Jan 21, 2013 | Computers & Internet
My computer stopped working in the regular settings, so i decided to do a factory settings restore, well it worked but now i cant get my computer out of safe mode, it automatically goes, no matter what i...
It only means that windows.ini was not successfully installed. You need to reinstall the operating system again or else your computer will be stuck on safe mode.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 21, 2011 | Dell Inspiron M5030 Laptop
Have a Dell inspiron 1525 after adding google and some extensions laptop shut down after the restart almost all of my Windows Services wont work or my firewall says it is off but wont let you turn on
Sounds like something got hosed up. i would recommend doing system restore to previous date when this was working fine. you will have to reload software that was installed after the restore date but this should not be hard. Click on start, all programs(programs for vista and windows 7) choose accessories, system tools and restore. chose restore computer to earlier date and proceed. If you cant do it in regular mode reboot pc and on reboot keep on tapping key F8 to go to safe mode and do same steps to do restore. Hope this helps.
Apr 17, 2011 | Dell Inspiron 1525 Notebook
Goes to windows and shuts down
Hi
Thank you for your query
Please try the following
1) Start Laptop
2) Continuously press the F8 key until a startup menu is repsented
3) Choose safe mode from the menu
4) Once safe mode has loaded up click on Start>Programs>Accesories>System Tools>System Restore
5) From system restore choose 'restore my computer to an earlier time'
6) From the calender presented please select a date in bold lettering back to before this fault was seen
7) Choose the date and click next..............follow the instructions through
If the system restore fails as above, then unfortunatley you will need to cary out a system restore, Please try the following
1)Put restore CD into drive and restart PC
2) Choose repair from the options and then follow on the on screen instructions
Feb 26, 2010 | HP Mini 1000 Netbook
Pc keeps loading and restarting again, it wont go past windows xp
I keep coming back to this, thinking about it, leaving and coming back to this. I have seen this before and the only thing that I could do to fix the issue was to do a Windows Repair using the original CD. The problem with this is it looks a little deciving and could be complicated. Put the CD in, accept the ULA and when it gives you the option to repair, hit R. Go through the prompts a little further. It will look like it is reinstalling Windows completely, but it is actually reloading just the system files that usually become curupt. When the system comes back up, it might look a little different, but all of your programs and files will still be there.
Mar 15, 2009 | Dell Dimension 4400 PC Desktop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
