Question about Viking DFSB423 Side by Side Refrigerator
How to adjust door viking dfsb423 - Viking DFSB423 Side by Side Refrigerator
    Novelist:
  • 150 Answers
Viking 42" built-in units usually don't offer any door adjustments. If one of the doors are not closing well, check for obstructions blocking the door bins, worn door gasket, and possible door warp-age on the panel ready models. Viking did have top hinge recalls updating to the new "Cobra" hinge on many of their models which can be verified by calling viking and providing your full model/serial numbers. If your Fridge door is lower than the freezer door you most likely have a worn door closer located on the lower hinge of the fridge door, the closer is a 2 piece plastic interlocking/mating unit which wears down over time from friction. This usually needs to be replaced. Pleazer Appliance...
Posted on May 07, 2014
  • 47 Answers
Depends on serial break of product. If after 100106, there is no adjustment except for high and low. Not doors being flush . Fz door will pull in as its lighter, ff door is heavier will not . Use the same springs .
Posted on Jan 16, 2015
Microwave door latch
Refer this matter directly to Viking
Jun 07, 2013 | Viking Refrigerators
One of the doors (on the Viking french door fridge) opens too wide (180 degrees). I want to tighten it so it only opens slightly more than 90 degrees. The other door is fine. Thanks.
Check with your Viking rep. I have the same problem and got word from Viking they are coming up with a new hinge doorstop at different angles. It will come in a form of a kit. The one I'm getting is about 100 degree opening. The problem I had was the door was hitting and adjacent electric oven from Viking. It just swung too wide.
Oct 29, 2010 | Viking VCFF036 Bottom Freezer French Door...
Oven doors do not close tightly? any suggestions
Adjust the latch on the oven body inwards to tighten seal on doors
Oct 23, 2010 | Viking VGIC485-6G Gas Kitchen Range
I want to adjust the upper doors on a viking french door model vcff036ff. The left door is higher than the right door. It appears that I have to remove the door to adjust it. Dan
USE A SPIRIT LEVEL ON THE OUTSIDE OF THE UNIT FIRST,IT IS POSSIBLY THE FLOOR THAT IS NOT LEVEL.........USE SPACERS UNDER THE FEET......factory build them square.....
Jun 07, 2010 | Viking VCFF036 Bottom Freezer French Door...
How do you adjust the door swing angle on the Viking VCFF036 bottom freeze French door model? What are the angles?
Check with your Viking rep. I had a problem that the door swings too wide. They said they are coming u with a kit to replace the door stop. I was told there will be a 100 degree doorstop kit for my problem The door when swung open gets a ding from an adjacent Viking electric oven with the professional door.
Jan 01, 2010 | Viking VCFF036 Bottom Freezer French Door...
One door lower than other, how to adjust door
The door can be adjusted with shims on the hinge post or by adjusting the cabinet by raising the front corner opposite the higher door. Keep in mind the doors are not designed to be perfectly even.If the difference is the depth of a quarter or less it is good. The seals making good contact all the way around is more important. Eric
Aug 08, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Needles hit lower looper
Adjustment needs to be made by authorized Husqvarna Viking dealer. You can find a list of authorized dealers near you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us If your local dealer is unable to adjust, have them send it to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for them to do the repair.
Good luck.
Jul 03, 2009 | Husqvarna Viking 1
Dishwasher: upper tray rolls out everytime the door opens
put 2 small pieces of cardboard under the front legs until you get it where it wont roll out anymore. i had the came problem with my kenmore and it took care of it
Dec 28, 2008 | Viking DFUD142 Built-in Dishwasher
Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Nov 24, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking DFSB423 Side by Side Refrigerator Logo
199 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Colin Stickland
Colin Stickland
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
