Why does the defrost light come on after a couple of minutes and it doesn't appear to defrost even though the fan is working?
  • 73 Answers
Unit is low on refrigerant
Posted on May 07, 2014
Sharp fridge
Can do the obvious and unplug for a couple of hours and test again. Components in the fridge will have run excessively so something may just have overheated. If that doesn't work you will need some more info, are there lights on? Do you have alarms, beeping? Can you hear any noises, fans running, compressor etc. I have had a couple of cases where after leaving the door open the fridge defrost timer has gotten stuck on defrost. Though I don't know if you have electronic control or mechanical.
Jul 10, 2013 | Refrigerators
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
Refirdgerator won't cool proprely on refridgerator side
Hi SN,
This could be a couple of things, but you should check for evaporator icing, even though you said the freezer is working and the defrost control appears to be ok. If the evaporator is iced up, no air willl flow into the fridge section even if the fan is running.
You can also check the damper control board. I am sending you a link that shows a complete breakdown of your appliance. I do not work for this company nor am I affiliated with them in any way. They also have a troubleshooting section and contact information. See:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5121995&diagram_id=29020886#d29020886
Aug 18, 2012 | Refrigerators
I have a 2003 dodge neon..and the rear defroster doesn't work..it has a button for it..and it just shuts off and back windshield doesn't clear at all...even if I keep turning it back on it...
Yeah, I'd think it would have lines, too, unless some new way of doing it that I'm not aware of. Maybe the rear window was replaced with a window without the defrost option. There should be a small two wire connector coming out of the back shelf near lower driver's side of rear window. That would be the defrost connector to the window lines (that aren't there,lol).
Well, good luck with that! I think there are aftermarket kits for rear window defrost, though.
Nov 23, 2011 | 2003 Dodge Neon
Rear defogger doesn't work even though dash lite works
Couple of things to check - first look for any scratches through lines, a couple of scratches will not let power run from side to side. The other is -> with a test light or voltage meter -> put (+)cable of meter/light to small electrical connector that attached to your window and (-) cable to a good ground (metal) light will come on/meter should read voltage there.
Mar 02, 2011 | 1998 Chevrolet Cavalier
Air conditioner/heater blower fan on 1997 Buick Riviera not working. Regardless of whether it's on ''Auto'', Vent, Recirc, or Front Defrost button setting, even though I can see the fan level meter going...
it will be hard to diagnose with out having my hands on it but try this.
this vehicle is known for blower motor resistor failure.
under the dash on the passenger side next to the blower motor there is a resistor attatched to the blower motor case it will have a single plug with 5 or 6 wires in it, they are normally within a couple of inches of the blower motor, remove this resistor and look at closely for any signs of burning this is a common problem, you can buy one at any parts house, do not operate the motor with the resistor removed from its mounting hole or you will damage it.
if the resistor looks good than purchase you a test light and drop me a line and i will explain how to test the entire system its not hard to do.
wesleyschacht@hotmail.com
Jun 14, 2009 | 1997 Buick Riviera
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Roper Fridge
You have one of the following problems which is indicated by the frost buildup. Your defrost timer has failed, or defrost heater circuit consisting of a defrost heater and defrost thermostat. Start at the defrost timer. May be located in the fridge compartment near the temperature controls. There may be a recess through which you can turn the dial SLOWLY clockwise until you hear one click. the freezer will be in defrost. Wait 18-22 minutes and the freezer should defrost and restart into cooling. If it does not restart after 30 minutes turn the screw clockwise again one more click and it should restart.
If you had to turn it again to get it to restart the timer is bad and needs to be replaced. If the timer restarted the cooling mode after 18-22 minutes and defrost did not take place your problem is in the heater circuit.
Jun 09, 2008 | Roper Refrigerators
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
