Bush lcd40fhda8 black screen sound ok
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: bush lcd30yv005 picture
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Aug 16, 2011
SOURCE: What is the sky remote code for the bush lcd40fhda8
Get a universal remote control
Posted on Mar 24, 2012
Flat screen has gone black but sound is fine
Suggest that you borrow a monitor from someone and try it on your system. If it works , you may have a defective backlight on your monitor , which means that you may want to replace the monitor. If the replacement monitor also is black , you probably have a video output problem , which would require repair of your computer.
Dec 01, 2014 | Bush Televison & Video
Bush 32inch tv has the power light on but has a black screen help?
Power light is there, and sound is OK, indicates the faut is with the horizontal output section. Check all the components in the horizontal output circuit. Line output transormer should be suspected.
Image of the suspected components attached.
May 08, 2012 | Bush Televison & Video
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Bush 42" rear projection rp40tv sound but no pic
any help please thanks tv turns on no problem but can not see any thing on screen. code comes up cant use menu do you no the code
Dec 16, 2008 | Bush 5693D 24" TV
Bush WS6671SIL POWER UP/VIEWING
Is the sound a high pitched whine? or an arching noise? since half the screen is black I would tend to believe it is a deflection problem. Which is the Horizontal section were having problems you would experience this. Ok first get a schematic for this television. Either contact the manufacture or get one from www.servicemanuals.com Open the set up. Determine where the sound is coming from I guess would be the switching transformer or the IHVT (Integrated High Voltage Transformer) Then if you have one get hold of your multimeter set to dc volts and begin to measure the power supply voltages leading to the Horizontal section. Your problem will be in these sections.
Sep 18, 2007 | Bush WS6671 28" TV
Bush 17" LCD TV
with your remote go into the menu and do you see that??? ok if you do go to the closed caption and see if its off. if its not then you have a backlight problem and you should seek professonal help with that. Good luck
May 11, 2006 | iiyama ProLite E430T 17 in. LCD Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
