Question about Cameras
Change iso settings
Lumix TZ40
My DMC-TZ40 will only turn on if I remove an reinsert the battery. Any ideas?
Possibly the contacts either on the batteries or within the battery compartment in the camera have become dirty. Try cleaning them gently with a cotton bud - no need to use any solvent, the slight abrasive action of the cotton fibres should be sufficient.
Jun 08, 2016 | Panasonic LUMIX DMC-ZS30DMC-TZ40 Digital...
How to connect panasonic to computer via usb lead
First download picasa 3 program its free. Then plud your cable into your camera then into your computers USB
Then in Picasa look for import and import your pictures name them and your done its easy. Goodluck Ozout!
Jul 24, 2014 | Panasonic Lumix DMC-TZ40 18.1 Megapixel...
I want to change language in the camera
Take it to Dealer or Authorized Service.
Apr 26, 2014 | Panasonic Cameras
Changing black white color
Answer is in the manual - in case you don't have it please do this:
To change selected picture effects ([Creative Control] menu)Press [MENU/SET]
Use cursor button to select [Creative Control] menu and press [MENU/SET]
Press up/down to select a setting ( there are a few eg. Sepia, Retro, Soft Focus, Expressive, Toy etc, and then press [MENU/SET] ( pressing DISP should give you an explanation of what each item selected does)
Hope this solves your problem.
Cheers
Mike
Dec 01, 2017 | Panasonic Lumix Cameras
How do you change the shutter speed on a Panasonic Lumix DMC-FZ7 Digital Camera? I want to take pictures of lightning with it, I have found the ISO settings find and changed them to what I want, but the...
You may change your shutter speed in Manual mode only. So you should turn your mode dial button to M position. Then you may control both shutter speed and aparture value.
Jun 03, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Concert photos
Not really possible with most cameras. Set the ISO to the highest setting and turn off the flash. This is the best you can do. Professional cameras that can shoot at ISO 3200-5200 are about the only cameras that can take that type of shot. Most pocket cameras do not have ISO above 1000.
Jun 04, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Over exposure photos
Try change the exposure of the camera: start the camera, set the dial to 'I' (automatic iso), then press the 'up' menu near the display until 'exposure' settings appear. move the slider to the left/right, according to your preference.
I reccomend using the automatic iso for taking pictures, it automatically adjust exposure.
Apr 25, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Change the ISO
Hi - You can download the manual by clicking the link underlined in blue below:
Lumix DMC-TZ3
See page 51:
The max ISO for this camera is 1250.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 08, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Nov 21, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
