Question about Prepology Set of 2 Stainless Steel Mixing Whisks - Blue -
How can wisk be fixed since shaft does not go in and out freely thus the bottom does not spin?
What can be done shaft of the wisk does not go in an out thus the bottom doesn't spin. What can be done to correct this?
Bottom propellers won't spin on my black spider xt
Had the exact same problem wire to gear was not welded properly reattach and done.
Nov 30, 2012 | Toys
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
I have an Elux Epic power nozzle that has a whine in it. Operation seems fine, there is no hair or material wrapped around the agitator bar. Any suggestions?
Does the brush spin during operation? Or rotate freely if you attempt to spin by hand when the machine is off?
Although uncommon in this age of vacuum, my first thought is a broken belt, which would result in no resistance to the motor shaft, thus causing a whine.
Oct 12, 2010 | Electrolux Epic 6500 Vacuum
What would stop the sprayers from spinning freely, A bearing?
Plugged, take em apart and clean all the crud out of them, its alot of work but has to be done.
Apr 22, 2010 | Hobart AM14C-155 Dishwasher
The fan comes on, the cuts out? Can it be fixed?
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 22, 2009 | Maytag M3V10S2A Air Conditioner
I HAVE A KIRBY AND IT KEEPS BREAKING AND BURNING BELTS.
Hello, Check this guide to be sure that your brushroll is in correctly. Follow it step-by-step and it should help of your brushroll spins freely. If it doesn't, there are new brushrolls available through the links in the guide as well.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jun 06, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Fan blade won't turn, but will slowly turn if given a push. What is the problem? How do I fix it?
Replace the fan motor capacitor. If that does not correct the problem you will have to replace the fan motor.
May 12, 2009 | Goodman CLQ36AR49 Air Conditioner
The attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Jan 15, 2009 | KitchenAid KP2671 Professional 6 Series...
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Prepology Set of 2 Stainless Steel Mixing Whisks - Blue - Logo
375 people viewed this question
Top Prepology Home Experts
john h
Tom Chichester
Are you a Prepology Home Expert? Answer questions, earn points and help others
