Question about Intex 10ft X 30in Easy Set Pool Package
How to oeperate the electric pump? - Intex 10ft X 30in Easy Set Pool Package
Keep putting in fuel pumps on 2007 buick rendevous and they work for a day or so and they fail? Could it be something other than the fuel pump?
Electrical problem ! Unless your using cheap fuel pumps . Did you try a Delco GM fuel pump . Do a voltage drop test on fuel pump electrical circuir also amp draw . Testing Electric Fuel Pump Problems with Voltage Drop Test
Jan 23, 2017 | 2007 Buick Rendezvous
Looking to change from vac. fuel pump to elec, pump
Tylon, Go for it, Electric pump may fix some difficult starting issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
MC54 250B Replace Fuel Pump Vacuum to Electric
Part 1 Parts you need for electric fuel pump install on your 150cc scooter...
Part 2 Facet electric fuel pump install into Flyscooters il bello 150cc...
Aug 18, 2016 | Cars & Trucks
Why no power to pump?
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Jan 01, 2016 | Water Heaters
How to change 1984 chrysler new yorker 2.6l from an electric fuel pump to a mechanical fuel pump.
Replace the mechanical pump with a new unit and that will remove any reason of broken/failure from the equation. Remove the electric pump altogether and leave 1 filter in the line before the mechanical pump. Mechanical pumps are not in favour with some people who have no idea that they can be adjusted to give more pressure and greater volume for the bigger capacity engines. Some mechanical pumps are more expensive to repair / replace but if you price an electric pump to supply the volume that a properly adjusted or a larger capacity mechanical pump then the cost saving is minimal. Unless you get a fuel filter that is rated with a smaller micron rating than the standard filter any number of filters will not work as the smallest particle will get through the lot
Nov 21, 2013 | Cars & Trucks
Steps replacing a 1985 grand marquis fuel pump for first time alone thanks
See Figure 1
Two different electric fuel pump configurations were used on fuel injected models. One consists of a low pressure in-tank boost pump in conjunction with an external, frame-mounted high pressure pump. The low pressure pump is used to provide pressurized fuel to the inlet of the high pressure pump and helps prevent noise and heating problems. System pressure is controlled by a pressure regulator mounted on the engine.
The other configuration consists of an in-tank high pressure pump which does not utilize a boost pump.
Fig. Fig. 1: Disassembled electric fuel pump
REMOVAL & INSTALLATION
In-Tank Pump
See Figures 2, 3 and 4
  1. Disconnect the negative battery cable.
  2. Depressurize the system and drain as much gas from the tank by pumping out through the filler neck.
  3. Raise and support the rear end on jackstands.
  4. Disconnect the fuel supply, return and vent lines at the right and left side of the frame.
  5. Disconnect the wiring to the fuel pump.
Fig. Fig. 2: Low pressure in-tank electric fuel pump
Fig. Fig. 3: High pressure in-tank fuel pump
Fig. Fig. 4: Removal of electric fuel pump
  1. Support the gas tank, loosen and remove the mounting straps. Remove the gas tank.
  2. Disconnect the lines and harness at the pump flange.
  3. Clean the outside of the mounting flange and retaining ring. Turn the fuel pump lock ring counterclockwise and remove.
  4. Remove the fuel pump.
To install:
  1. Clean the mounting surfaces. Put a light coat of grease on the mounting surfaces and on the new sealing ring. Install the new fuel pump.
  2. Installation is in the reverse order of removal. Start the vehicle and check electric fuel pump operation. Check for fuel leaks.
High Pressure External Pump
See Figure 5
  2. Depressurize the fuel system.
  3. Raise and support the rear of the vehicle on jackstands.
  4. Disconnect the inlet and outlet fuel lines.
  5. Detach the electrical harness connection.
  6. Bend down the retaining tab and remove the pump from the mounting bracket ring.
  7. Install in reverse order. Make sure the pump is indexed correctly in the mounting bracket insulator. Start the vehicle and check electric fuel pump operation. Check for fuel leaks.
Fig. Fig. 5: High pressure external fuel pump
Feb 12, 2011 | 1985 Mercury Grand Marquis
Gets really hot but only for 2 short showers. Ran d/w this morning and no hit water for about 2 hrs. Tried curcuit breaker and reset button on heater worked last night.
My guess would be that the heater elements are coated very heavily with calcium deposits and are not oeperating effecient enough to keep up with use. These can be removed and replaced or cleaned but the tank itself would also be suffering the same problem. I have never tried decalcifying a tank because the age of water heaters are usually more energy and money saving to just replace. sorry
May 16, 2010 | Water Heaters
No Oeperating system found
it is possible you have a cd in your cd-rom or a usb drive in your usb port that is trying to load first.
take those out, see if that helps.
if not, it possible you have a corrupted boot sector.
check the hard drive for errors.
thanks
Apr 25, 2009 | Computers & Internet
Lucida estima
Electric. All fuel injected vehicle must have an electric pump.
Jun 10, 2008 | 1993 Toyota Previa
Intex 10ft X 30in Easy Set Pool Package Logo
20 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
