Question about Canon FAXPHONE L170 Plain Paper Laser
I cannot receive faxes from my Canon Faxphone L170 .......
Everything seems to be hooked up correctly, when someone tries to fax it says, my machine is busy, HELP ME
  • 1 more comment
  • pick3selecto Jun 22, 2009
    I have the phone cable connected to the telephone line jack and the handset jack connected to the handset jack
    yes I can fax out
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    do you have the phone cable connected to the input socket or output socket (phone)?
  • 331 Answers
Can you fax out from the machine?
Posted on Jun 22, 2009
  • Raymond Ramirez
    Raymond Ramirez Jun 22, 2009
    would you happen to have new or a different phone cableso we can make sure that one of the pins did not break.
CANON FAXPHONE L170 FAXES ARE STUCK IN THE RECEIVE GREEN LIGHT STAYS ON
You can do clear all under service mode, but you will loose all data.
MENU and #, clear, ok, all, ok
reenter all your sett. and try to get fax from someone.
Jun 30, 2010 | Canon FAXPHONE L170 Plain Paper Laser
Volume on Canon Faxphone L170
By pressing the menu button left of the LCD display,scroll to usersettings press ok.Scroll to volume settings press ok and change volume levels there.
Dec 11, 2009 | Canon FAXPHONE L170 Plain Paper Laser
We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
Dec 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Would like to receive legal faxes through mpf on my canon l170
Starting on page 4-8 and continuing thru step 3 on page 4-9 will allow you to setup the mp feeder for legal size paper on your Faxphone L170.
http://gdlp01.c-wss.com/gds/0900006140/FAXPHONE_L170_Basic_Guide_EN.pdf
Oct 26, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Can not receive a fax on the cannon L170 Super G 3
Make sure that the phone cord from the wall to the fax is plugged into "Line" and not "phone" .
Aug 12, 2009 | Canon FAXPHONE L170 Plain Paper Laser
L170 Canon Fax Sound and volume control issues
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Can not transmit faxes
do you have a seperate fax line? if so check the fax line.
also in the fax menu set up your fax to phone/fax mode, and set up all your fax info.
if you have distinq ring you need to set up your # of rings.
Feb 22, 2008 | Canon FAXPHONE L170 Plain Paper Laser
No dial tone, clicking sound
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
Jan 29, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
Canon FAXPHONE L170 Plain Paper Laser Logo
369 people viewed this question
old marine
old marine
