How do i replace belt in a thor th1050? - Washing Machines
Thor 23H Motorhome
If you have a question about a Thor RV, suggest you contact Thor. https://www.thormotorcoach.com/
Aug 20, 2017 | RVs
2012 Thor Challenger 36FD; Auxiliary batteries went dead, tv recepticals and generation not kicking on. Charged batteries, but no change. Is there a reset button or maybe a fuse that I might need to...
Hi Thomas,
Why yes. I am offering you the direct site for IRV2. There you will find direct assistance for troubleshooting by phone in real time.
2014 Thor Challenger 37KT Owners iRV2 Forums
Here is the another. Not the same as above.
2014 Thor Challenger 37KT Owner Thor Forums
My assessment will be the automated transfer switch is not working. If the battery pack is below specified charged levels. The system has a protection circuit not to allow the transfer from the grid to isolation switch. When the charge is achieved to satisfactory levels. Then it will function.
It is possible you may have a shorted cell in one of the batteries preventing the charge to be successful. I would observe the water levels in each battery and every cell. When full there is a mirror like image in each cell designed to indicate the level. A run down battery will have very low levels at either end of it. The hydrometer is the best way to see specific gravity. When found then isolated you can remove from the series.
A blown fuse or tripped breaker protects the downstream equipment and the power control board.
There should be a shop manual somewhere in the RV. Customer service is available at the links offered. Fare. well.
Jul 06, 2014 | Thor Motor Coach Challenger 37KT RVs
Where can I get a 2015 Thor motor coach Vegas service manual or 2014?
Chassis will be one manual, coach will probably be generic from Manufacturer.
May 24, 2014 | Thor Motor Coach 2014 Vegas 24.1
The lights in my 2000 25ft Thor Tahoe slideout are not working how do I troubleshoot
use a meter to check the sockets for voltage either 110acv or, 12v dcv
if dcv it's is your batteries or inverter not supplying power check with a meter set on dc volts; if ac check your circuit breakers with a meter set for ac volts if these are fine then replace switches
Nov 26, 2013 | Thor Motor Coach RVs
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
Eidos tomb raider underworld
Leap onto the slab near the second spout, then climb up to a grip. Leap from the grip to the rod in the serpent head's snout to stop the flow. Climb down using the grips underneath the spout. Grapple on the screw in the center and yank it as you move counter-clockwise (with the Thor statue as 12'o clock) around it. It should screw into the ground, stopping the flow for good and allowing access to a chamber inside the Thor statue.
Mar 10, 2009 | Eidos Interactive Lara Croft Tomb Raider:...
Misplaced faucet adaptor
They're odd ball since they're metric on the washer side. Best bet would be to google Thor washers. They sell quietline parts.
Also, if there is a cheaper alternative source... their tech support guy doesn't mind suggesting it. He sent me to auto parts store for a main belt for mine... worked fine...
Aug 17, 2007 | QuietLine WD-9900 Front Load Washer /...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
