Question about Rinnai Water Heaters
How do I turn down thermostat on this water heater?
Rinnai RIN160E24 is too hot! The water in the house we just bought is scalding-hot. Thermostat dial reads down to 40 but will not turn below 60. Any ideas? Thanks!
    Sergeant:
    Champion:
  • 282 Answers
The temperture of a water heater should be approx 120 degrees. If you use a dishwasher that is the desirable tempurture to kill bacteria.
If your heater has two thermostates then make sure they are set for a 5 degree difference between them
Good Luck,
Marty
Posted on May 13, 2014
  • wa2yyx May 22, 2014
    Well, it all depends on the capicity of your water heater. Say you have a 40 gallon hot water heater and all of those people are taking showers one right after another. Of course your going to run out of hot water. There are several solutions I can suggest. Depending on how old your hot water is you may be better off replacing it with a new higher capicty heater or another option is to get a water restrictor placed in the shower head to limit the flow of hot water.
CRTN
  • 716 Answers
SOURCE: No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Posted on Jan 16, 2009
  • 63 Answers
SOURCE: water is no longer hot
probably the thermostat ,also this could be your dip tube broke (burned) off! this tube takes the incoming cold water and sends it to bottom of tank! so only the hot water comes out the top...if broke, the incoming water mixes in the top of tank and presto! lukewarm water.. also I want to point out, as a plumber of 25 years, replacing estimated 200 plus tanks..that the average lifespan of tanks seem to be 11 years....really! so don't spend too much money on this one ! John
Posted on Apr 07, 2009
  • 9 Answers
SOURCE: 12-year old Rheem residential single-thermostat
TIME TO REPLACE TODAYS ARE MORE EFFICIENT
Posted on Sep 08, 2009
  • 45 Answers
SOURCE: My Rinnai tankless water heater cycles up and down
You need to first make sure is the tankless who do the “up and down”! . If the problem manifest on more then one faucet then the problem is the unit. Have a thermometer (we use a infrared gun wich we train on Hot water pipe !) and see if actually the unit is the culprit.
If the problem is only on one shower It is possible also to be a “antyscalding valve” If the trigger valve on your shower is being adjusted too low then it trigger a splash of cold water now and then on regulate intervals. Try to adjust the temperature lower at the unit (say 110F ) and see if the problem change. If it does, then the problem is for sure in the faucet. If it does not change , then you have a problem with the water flow sensor . It is simply getting stuck. Bad bearing or even a piece of Teflon tape. I believe you will need a certified technician for that so no issues with your warranty will appear.
Posted on Jan 13, 2010
  • 148 Answers
SOURCE: Hot water does not last long.
probably has a bad heating element. May be a little limed up also. Drain the heater and replace the elements. Take a special tool to remove and replace the elements. ( fairly cheap) You can probably get the elements and parts at a good hardware store. The people at the store probably will explain to you how to replace them. Feedback please if this was of help
Posted on Feb 20, 2010
My hot water is scalding hot and won't go down when I turn the thermostat own. Is it the thermostat?
Probably a faulty thermostat but a possibility, depending on design and area that heavy internal scale deposits are preventing the thermostat doing a good job.
Aug 03, 2016 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heater not getting hot enough
Open the access door to the thermostat ( about 3" wide & 9" high, two screws) At the bottom of the thermostat there is an adjustment screw on an arrow and dial. Factory settings are at 120% for residential heaters. Reset to 135% is hot but it will not scald anyone. Higher temps are dangerous especially to those used to the old setting (if there are 2 doors reset both thermostats)
Jan 31, 2015 | Water Water Heaters
I have bought a used Rinnai R94LS natural gas tankless water heater and need to know which thermostat to buy for it? I have bought a used Rinnai R94LS natural gas tankless water heater and need to know...
Plumbcentre have a parts desk for gas appliances.
most appliances are available to view in an exploded view with clear identification of parts.
However when it comes to gas, I strongly advise on using a GASSAFE engineer
Nov 18, 2014 | Water Heaters
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
Reliance 501 water heater and I cant find a way to turn it DOWN ..the water is scalding
Replace both thermostats and test both elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.htmlhttp://waterheatertimer.org/How-to-test-water-heater-element.html
Power is off while doing these repairs.
If water is hot, then you know that electric line and circuit breaker are working correctly.
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
Rinnai Infinity 26 hot water system set to 55 degrees with remote temp adjuster. Water only luke warm for showers. Burnner working, water & gas pressure ok. Any thoughts ... Stephen
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
Jul 09, 2010 | Rinnai Digital Remote Water Heater Control...
Cant find replacement Rinnai thermostat
Try National Energy they are on line they sell spares they may be able to help .
Apr 10, 2017 | Rinnai Digital Remote Water Heater Control...
I need the manual for a Rinnai Infinity 26 hot water system
you can get it off the rinnai web site they have a spot on there to get the internet manuel,, but from what you are saying you may need to adjust the thermostat, or the temp, remember even though you will have endless hot water it still takes the smae amount of timed for the hot water to get to your faucet,, not only that make sure your shower heads aren't holding back to much water pressure, if you don't have enough water going thru the unit it will not stay lit, if will come on and go off, judt to dstisfy the unit,, make sure the filter is clear, on the cold side there is a cap screw if you take it off there is a screen in side you just pull it out and clean it and reinstal it,,
Jun 25, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
111 people viewed this question
Top Rinnai Water Heaters Experts
gizmonix
Level 1 Expert
James Feragola
James Feragola
Level 1 Expert
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
