Error code E35 what is this?
Hi we have a Zanussi Jetstream 1200 washing machine. It is stopping 3/4 the way through a cycle especially on quick wash programme. we followed a feed on here to get the error code and the error code is showing E35 which apparently is water level too high. We have noticed that the water level is high at times, but can you advise what is causing this or how to fix it? Many thanks Nesta
  • 41 Answers
Switch off the elec remove lid and check the pressure switch tubing is not been rubbing against the side of the mach and wearing a tiny hole into the tubing .there is sometimes 2 tubes looking from the rear of the mach they are at the left handside not the best place i normally take the rear half of the mach off to gain access .also it only needs apin hole or less to cause bother take care hope this helps
Posted on May 11, 2014
  • 641 Answers
SOURCE: zanussi error code 30(model zws 1640s)jetstream time line.
Does the machine drain out water in the beginning of the process ? In case it drains out water: -Check first the filters on the inlet water line. - If problem still exist,test for 115/220V on solenoid tags. Good luck !
Posted on Aug 06, 2007
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
  • 6 Answers
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Posted on May 08, 2009
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
  • 193 Answers
SOURCE: error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Posted on Oct 30, 2009
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
ZANUSSI JETSTREAM, CODE E20 appears with every wash near the end of cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out
If still the problem persists then the problem is with the draining pump.Replace it and this wont come again
Thank You
Sep 09, 2010 | Zanussi Washing Machines
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
Noisy during some parts of the cycle
it could be the concrete ring situated at the front of the machine. i had the same problem with mine 2 years ago.
Jul 29, 2008 | Zanussi FJD1266W Front Load Washer
Zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
Nov 12, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi error code 30(model zws 1640s)jetstream time line.
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
