Question about Honda Garden
Needs oil change ; what is correct oil to use ?
Honda pressure washer gx 340 . it has a gearbox connected to a comet pump . i need to know the correct oil to use in the gear box and the pump . its a european model .
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
Posted on May 09, 2014
lilmikew99
  • 122 Answers
SOURCE: Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
Posted on May 12, 2009
  • 56 Answers
SOURCE: what oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Posted on Jan 04, 2010
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
  • 760 Answers
SOURCE: what type of oil goes in a comet axd 3020 pressure
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
Posted on Jul 14, 2010
  • 57 Answers
SOURCE: There are 2 different places to add oil to my 3500
you can use sae 30 in the motor and hydraulic oil or gear oil in the pump.
just note that there may be two oil filler holes on the motor.
Posted on Jan 10, 2011
Testimonial: "Thank you very much for verifying the oil for me."
What oil do you use in gear box of gx 340
If it's a pump gear box then use 80-90 gear oil
May 04, 2014 | Honda Garden
Y a t'il un niveau d'huile dans la comet bxd 2525
L'utiliser cette pompe sans huile est une erreur fatale:
[PDF]COMET PLUNGER PUMP SERVICE MANUAL INDEX
www.cometpump.com/_images/support/Pump_Repair_Manual.pdfLUBRICATION: Make sure crankcase is filled with Comet Pump oil. Running this pump without oil will cause damage and void any warranties. Change the pump ..
Mar 14, 2014 | Comet BXD 2525 G Pressure Washer Pump
I have a Pressure Washer VR2500 , 6.5 horsepower / 2500 PSI number on side 123K12-0134-E Residential - Excell. I do not know which is the oil drain plug for the Pump on the bottom. There is an Allens...
Hi and welcome to FixYa, I am Kelly
First here is the owders manual:
http://www.excellpressurewasher.com/documents/pdf/D30494-E.pdf
There are 3 versions of the VR2500 Pressure Washer.
1 being the VR2500 Type 0 It has the comet pump that needs no oil
2 being the VR2500 Type 1 Also with the comet pump.
3 being the VR2500-C Again with the coment pump
The allen set screws that you removed hold the bearings in place.
The only pump maintence required is winterization with either a winterizer EX80 or RV anti-freeze
PUMP
The manufacturer recommends using
a pump protector/winterizer, such as
EX80, when storing the unit for more
than 30 days and/or when freezing
temperatures are expected. If a pump
protector/winterizer is not available,
*RV antifreeze needs to be run through
the pump as outlined in the steps
below.
EXCell does make units that have an AR pump that requires pump oil. The VR2500 pump does not.
Thanks for choosing FixYa.
Kelly
Dec 06, 2010 | Comet GXD2527G Pressure Washer Pump
Oil window broken
we have a honda gx 340 11.0 dont know what type of oil to use.
has 3 different oil type plugs????>
Sep 28, 2010 | Honda Pressure Washer PSI 3000
Looking for manual for honda pressure washer,its a GX 340 11.0 HP that I can view online without buying so I can find the part and part number
Go to this page:
http://www.jackssmallengines.com/help.cfm
You must have your exact engine model number listed on the side of the engine crankcase near the lower mount and oil plug.
Thanks for choosing FiXya.
Kelly
Jun 23, 2010 | Honda Pressure Washer PSI 3000
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Oil for Comet pump
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Laking below sprayer large rubber piece covers area that is leaking
Sounds like your thermal relief has popped and is not reseting. These are an easy replacement. Usually availble as a "thermal relief valve" in sizes 3/8npt or 1/4"npt ..national pipe thread. Might also mean that your pump is overheating. Check and replace the pump oil. Make sure you do not allow this sprayer to sit and run without triggering the gun every couple of minutes.
May 01, 2009 | Garden
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
255 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
