Question about Xerox WorkCentre 5330/P Printer
How to enable https in Xerox 5330 - Xerox WorkCentre 5330/P Printer
Xerox WC 5330 error Code 010 338
I think it is a toner or maybe paper issue, as a first step I would remove and re install both
Jul 13, 2016 | Xerox WorkCentre 5330/P Printer
I have new xerox 5330 , but we lost our USB to install software comes with it, now what I can do? and what is the passcode??
go to the xerox web site and download the software. it has instructions on how to reload. admin 1111
Jun 16, 2016 | Xerox Office Equipment & Supplies
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
Error code 116 330 workcentre 5330. already several times tried power ON OFF. but still same error is coming...
This code is HDD fail. You may be able to reformat by holding down stop, start and 4 keys and turning on power. failing this try stop,start and 6
Feb 14, 2015 | Xerox Workcentre 5330/p 5330 Mono Advanced...
How to fix fault 116-365 of wc 5330
Solutions for : Fault Code 116-365: An Internal Shutdown Occurred After an SPL Processing Error Related Fault Code: 116-365 Solutions ranked by relevance:
  1. Delete All Jobs From the Job Queue
  2. WorkCentre 5325/5330/5335: Power the Printer Off and On
May 27, 2014 | Xerox Office Equipment & Supplies
Xerox WorkCentre 5330/P Printer Logo
19 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
