Question about Garden
I have a pedrollo pump that pressurise our sprinkler systems i took it for servicing and came back to install found out that the opening on the impella side is discharging water like opening a tap it floods the pump room please advice why this is so?
    Champion:
    Habit-Forming:
  • 210 Answers
There doesn't seem to be enough pressure. If it is connected with the sprinklers, you might have to separate the two. You can try to increase the pressure but be sure not to break the sprinkler system.
Elisa Jed ' http://www.dwestenterprises.com/irrigation.html
Posted on May 24, 2014
5 Suggested Answers
  • 5 Answers
SOURCE: Sprinkler system, pump makes humming nose but never turns on
Is this a MQ3-35??? If so, it is most likely the capacitor. This is easy to replace. Take out the 4 screws from the push button cover. The capacitor is the white plastic cylinder with wires plugged in the top. Put the wires in the new capacitor exactly the same as the old one. Be sure to unplug that pump before you do anything.
Posted on Aug 29, 2009
SOURCE: Flotec Sprinkler Pump not priming
it might be that the pump is prewired at 230 volt and you are running a 115 power supply to it, if motor just humms and little water comes out this might be your fix
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: Sprinkler system problem.
the bleeders or solenoids are probably open or loose on all the zone valves.close each of the bleeders and the water in each zone will stop.The zone valves are usually installed ad part of a manifold enclosed in a green box installed flush to the grade or grass. Pull the cover off to expose the zone valves
Posted on May 04, 2009
mark24354
  • 776 Answers
SOURCE: We have an above ground
Sounds like this is an issue of gravity allowing the lower level fountains to take all the water from the central (higher) fountain.
The pump needs to either be much stronger OR you will need to restrict the flow out of the lower fountains until the upper fountain starts to work OR reduce the number of lower fountains (this is just another way of restricting the flow out of the lower fountains).
I don't have details of your pump and fountain models but you won't get water up to the higher fountain if it can flow out of the lower fountains faster than you can pump it.
Good luck.
-Mark
Posted on May 21, 2011
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    How to install a sprinkler system ?
    Sprinklers installation, especially pop up sprinkler installation is not simple generally.I tried installing it in agricultural land as per the advice of my friend.He also assisted me.But afterwards i had to call a professional to complete the installation.But i think for a garden we can do the installation our own.
    Dec 19, 2013 | Flotec 1 - 1/2 Sprinkler Pump Composite...
    Not enough flow and pressure to run sprinkler system
    pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
    volume flow is also important as a pump without a high output will not produce pressure
    check the jet size at the foot valve that is used to help lift water to the pump
    It is a jet pump and will have a smaller line back to the foot valve for that purpose
    next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
    you indicate 4 sprinkler heads per zone but how many zones are operating at one time
    check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
    check also the rpms of each pump as that also has a bearing on volume produced
    Mar 26, 2017 | Flotec Pump FP4032-10MK
    What are some different types of sprinkler systems i could use for my lawn at home?
    the most common residential systems are impact spriklers, underground sprinklers, drip sprinklers, or oscillating sprinklers
    Jan 28, 2013 | Garden
    I have an aquamate pump and when i connect it to a continuous sprinkler it stops and starts contiuously
    The pump is putting out too much water for the sprinkler.
    You can raise the pump shut off pressure at the switch until it is higher than the pressure that the pump runs at with the sprinkler operating. You should have a surge tank connected to the system to give the pump time to balance with the sprinkler.
    You can use more water with the sprinkler. This could mean adding another sprinkler or increasing the nozzle size of the existing sprinkler.
    Dec 05, 2010 | Garden
    I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
    I don't know what is your system set up. However, the system set up should be the following;
    1. Your 1-1/2HP sprinkler pump must be installed at
    a fix location nearest the water source. (Complete
    with power and plumbing lines.)
    2. At the end of the suction line is a vertical check
    valve with strainer.
    3. The suction pipeline must be connected to the
    suction port of the pump.
    4. At the discharge port, a flow control valve tee must
    be installed. The flow control valve tee top is
    covered with a plug, which serves as the priming
    port when opened.
    5. After the flow control valve, connect a short nipple
    so that you can put a gate valve to stop the water
    flow or allow the water to flow. You may connect
    a pressure tank at this point or you may connect
    the pressure hose going to the sprinkler.
    6. To prime the pump, open the plug at the flow
    control top. Fill it full with water, replace the
    priming port plug.
    7. Turn the flow control valve to full closed position.
    8. From full close position, switch the power on.
    9. The pump now run on and off due the pressure
    switch setting. Slowly open the flow control valve
    such that the water pressure remains steady.
    10. Take note of the pressure.
    11. Shut the power off, and connect the sprinkler
    pump hose.
    12. Put the power back on, and allow the pump to
    run with the sprinkler.
    Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
    Dec 08, 2009 | Plumbing
    Mar 13, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
    Garden Logo
    171 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
