Question about Sony FD Trinitron WEGA KV-32FQ70 32" TV
What is LOT transformer - Sony FD Trinitron WEGA KV-32FQ70 32" TV
    Top Expert:
  • Sony Master
  • 74,459 Answers
LOT is [Line Output Transformer] which generates EHT and other voltages needed for the CRT. what is LOT transformer - 286c4876-057c-4281-bc57-397dccd574d9.jpg
Will look somewhat like this.
Gopakumar Gopalan Google
Posted on May 06, 2014
What is the name line output transformer(L.O.T) for LG colour tv circuit?
Line Output Transformer [LOT]. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 16, 2014 | LG Televison & Video
Transformer fire
Most small motors are 12 volt, but they do vary. If your transformer melted down, There is a good chance something else caused it, So just replacing the transformer would not be worth it. A lot of printers, copiers etc, have transformers in them that would work, motors too for that matter, but electric typewriters are fairly cheap now days.
Apr 17, 2012 | Office Equipment & Supplies
TV COMES ON BUT GOES BACK OFF
Line output transformer ro Line output transistor to your tV is faulty. Just replace the Line putput transistor first. If it do not help you, replace Line output transformer {LOT}.
Mar 16, 2012 | Televison & Video
Where is the flybac located in a rca hd52w59
Hello
Flyback transformer other wise called Line output transformer {LOT} is actually a step up transformer, which supplies extra high tension voltages to the guns. It can be locatee on the main printed circuit board. 2_7_2012_5_19_59_pm.jpgJust see the different views of the main board of your RCA TV. You can see the flyback transformer at the left top corner, look like a large black componen; with a ferrite "U" type core goes though it. It is the LOT. Line Output Transformer, otheriwse called as Flyback Transofrmer. OK.
Feb 07, 2012 | RCA Televison & Video
I need a transformer
Hello
It is not clear from your post, that which transformer part number you wants to know. Anyway I'm hereby send you the part numbers of it two main transformers.
[1] Horizontal Ouput Transformer, or Line Output Transformer or Flyback transformer [HOT or LOT or FBT]; Part number is (257807)
[2] Switeched Mode Power Supply transofrmer [ SMPS transformer]: Part number is (257807)
OK.
Dec 16, 2010 | RCA F36650 36" TV
My Sanyo is making a noise that's been a little quite but now its louder and it would usually go away but its not. Please help I don't want to use the small tv
One anong your TVs transformers causing the problem. Usualy, on all tvs ferrite cored transformers are used. If the core of the transformer get loosed, it will make a whisling noise. To get the faulty transformer, you must open the back cover of the tv and listen which transformer makes noise. Usually core of LOT will vibrate. After recognising the transformer which makes noise, press its core with a wooden or plastic matereial to sure the transformer under concern is it or not. Fix its core joints with some super glue, without seperating it you can do that. Take caution. There are severel very high voltage points are ther inside the tv.
Oct 13, 2010 | Sanyo HT32744 32" TV
What if caps are good and transformer is bad on ilo 32 flat t.v. with power supply problem?
then you need to replace the transformer.If you are not sure that the transformer is bad just use a multimeter to test it. There are a lot of helpful websites that have step by step instructions on how to test them, but in most cases if a transformer is bad you will see burn marks on it.
Jun 12, 2009 | iLO LCT32HA36 Television
HID headlight
Most likely the HID transformer is not producing the correct voltage to properly charge the HID bulb. 12 volts goes into the transformer, but a lot more comes out. The HID needs a lot of volts to run, hence the need for the abovementioned transformer. But, the transformers are REALLY expensive.
Sep 18, 2008 | 2004 Toyota Sienna
My unresolved question
Low Voltage Output Transformer, is a very common term for this abreviation LOT. I have also heard it referred to Line Output Transistor, or Line Output Tranformer, and a vew others.
Jerry G.
Apr 12, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Sony FD Trinitron WEGA KV-32FQ70 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
