Question about Vacuums
Why is my Hoover brushes not working and no suction
The switch is on floors but Hoover brushes not rotating and no suction
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Brush motor reset button? Clean out brush.
Posted on May 06, 2014
SOURCE: brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
Posted on May 18, 2008
  • 294 Answers
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Posted on Mar 15, 2009
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at lostnhisblueyes@aol.com
i took off so many more screws than i needed to to get this figured out so dont do that.
Posted on Apr 03, 2009
  • 4088 Answers
SOURCE: brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Posted on Jul 12, 2009
nwj2468
  • 76 Answers
SOURCE: Hoover 6446 900 WindTunnel Bagged Upright has
check for a clog in the brush hose
Posted on Aug 22, 2009
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
The Hoover switches on and the brush rotates but the actual Hoover doesn't come on?
Hi, is there suction when you open the top of the wand handle?
If no, have you emptied the container. next check the tubes that are removable, you may find there is a blockage of hair and bits, have you removed filter and given it a goos wash.
Jun 04, 2014 | Dyson DC25 All Floors Bagless Upright...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The brushes and the belt are not rotating. The power seems fine and there is suction. I have no other history on this problem since I was given this almost new unit over Thanksgiving. Where should I be...
If you've got suction, but the brushes and belt are not rotating, then either the belt has come off the motor shaft, or the belt is broken and just looks OK.
Remove the bottom cover off the floor head and check that the brush roller turns freely. If it does, then check the belt.
Let me know if you need additional repair information.
Dec 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Jan 12, 2009 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
