Question about Panasonic Advanced Hybrid Kx-t7730 White 12 Button Spea
TO OPEN 00 - Panasonic Advanced Hybrid Kx-t7730 White 12 Button Spea
What are the hours of the aldi store in raymond terrace
ever heard of a phone call to ask them . we have no idea on FIXYA as to when they work or even where raymond terrace is
Dec 22, 2016 | The Watches
What of when 6L is blinking
5 02 Copy lamp lighting abnormalityH2 00 Thermistor open
H3 00 Heat roller high temperature detection
H4 00 Heat roller low temperature detection
L1 00 Scanner feed trouble
L3 00 Scanner return trouble
L4 01 Main motor lock detection
11 Shifter motor trouble
L6 10 Polygon motor lock detection
L8 01 No full wave signal
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication
Jul 15, 2014 | Sharp AR-M205 Copier
I have a Sharp ar168d. The unit has had the triangle shaped warning light blinking. I talked to a service man and he said as long as it is still working don't worry about it. Now is has stopped. Tryed to...
Welcome to Fixya
H2-00 means Thermistor open - Open upper heater thermistor or the fusing unit is not installed when the door is closed.
L1-00 Mirror feed problem - make sure the mirror lock is not on or remove
Please click here for the complete list of error code of your printer and how to reset the printer.
Thank you for using Fixya!
Apr 20, 2011 | Sharp AR-168D Copier
I need to change the name that appears on faxes
Product Support and
Technical Assistance
1-800-211-PANA (7262)
en Español
opcion #2
Hours
Mon-Fri 9:00 AM - 9:00 PM EST
Sat-Sun 10:00 AM - 7:00 PM EST
http://ops.novacopy.com/usermanuals/Panasonic/DP2330_3030.pdf
Open the link and check the manual.
Mar 09, 2011 | Panasonic Workio DP-2330 Printer
Hardware problem occurred
Check to see if the cover arm broke off or has missed the lever that makes it operate when you drop the cover down if this does not do it Let me know I will see if I can find anything else but that's all I can think of at the moment, get back to me if that does not fix it and I will see what I can find for you, do the simple first. Thanks for using fix-ya
Jan 19, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Unexpeted close promodag.
Olmapi32.dll is one of the MAPI components installed with Outlook 2007. I think that your current configuration file contains one of the following conditions: account impersonation in the Exchange Connection tab of Tools > Options, and/or a hidden mailbox to establish that connection to the Exchange system. That could work with Outlook 2003, but not with Outlook 2007 or 2010.
Can you follow these steps:
  1. Locate the Repex.pri file, that you should find in the %SYSTEM%\ProgramData\Promodag\Reports\8\ directory.
  2. Edit it using NotePad.
  3. Delete the following values (xxxx in red):
    • MAPIServer = xxxx
    • MAPIMailbox = xxxx
    • MAPIUseNTSpecific = x
    • MAPINTAccount = xxxx
    • MAPINTPassword = xxxx
    • MAPIUserName = xxxx
  4. Save the Repex.pri file.
  5. Start PROMODAG Reports.
  6. Go to Tools > Options and open the Exchange Connection tab.
  7. Enter your connection settings (user account and mailbox) and make sure that the following conditions are met:
    • The user account is a member of the local Administrators group.
    • The user account is a member of the Exchange View-Only Administrators group.
    • The user account is associated to a mailbox and you select that mailbox (Outlook 2007 MAPI client libraries do NOT support impersonation).
    • The mailbox is not hidden in the Global Address List (Outlook MAPI client libraries would make the application crash).
I believe this should be sufficient to solve the problem.
Best regards,
Pierrick Lussan
PROMODAG
May 26, 2009 | Software Shelf International Promodag...
Recyclebin rename
Hi there,,
Please follow the instructions:
  1. Click Start / Run
  2. Type regedit and press enter.
  3. Open the HKEY_CLASSES_ROOT folder
  4. Open the CLSID folder
  5. Open the {645FF040-5081-101B-9F08-00AA002F954E} folder
  6. Open the ShellFolder folder
  7. Change the "Attributes" data value from "40 01 00 20" to "50 01 00 20". Once completed change the "CallForAttributes" dword value to "0x00000000" (double-click and change value data to 0). You must change both of these values to get the rename to appear.
After performing the above steps you will be able to rename the icon like any other icon. Right-click the Recycle Bin icon on the desktop and click Rename and rename it to whatever you wish.
Thanks,
Vipin Menon
Mar 16, 2009 | Microsoft Windows XP Professional With...
DVD player wont open says E:26:00 then shuts off
Solution #3 worked for me.
http://www.fixya.com/support/t127790-error_message_e_26_00
Mar 13, 2009 | Sony OPEN BOX SLV-DP550P DVD/VCR Combo...
The cd drive
i would call ms and tell them that it just stopped working.
contact details below:
Assistance by phone:0800 587 1102
or +44 20 7365 9792 from a mobile phone
Hearing Impaired (TTY device):
0800 587 1103
Hours of operation:
Monday-Friday: 09:00-22:00
Saturday: 09:00-20:00
Sunday: 09:00-17:00
Aug 12, 2008 | Microsoft Xbox 360 Console
Unable to open a wmv file
Try removing Windows Media Player and redownload verrsion 10 and install it.
See if you get it to work there...
Jul 19, 2008 | Computers & Internet
Panasonic Advanced Hybrid Kx-t7730 White 12 Button Spea Logo
12 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
