Question about Sony DVP-SR200P DVD Player
I would like to know where the tiny hole in the front of the tray is?
The face of my dvd tray is off but can not see any tiny hole to open the tray. Can you show me a picture of where it is please?
    Master:
  • Sony Master
  • 752 Answers
I can't help with a picture of the same unit as you have, perhaps you can post a picture of yours with DVD face removed (there isn't such a hole on the intact unit). so that I can inspect it. Your DVD player may not have such a hole. If you consult your user manual I think it tells to you to take the unit to a Sony service centre, but you could the support section of their website. Meantime I attach a picture of computer DVD player, with the hole inside a white ellipse that I have marked in between the LG logo and the button. It's not very visible, being less than 1 mm in diameter (just wider than a paperclip)
6.May.2014 I would like to know where the tiny hole in the fr - 524afd0e-cd1d-47f4-97f7-25c5fe31de77.jpg
Posted on May 06, 2014
Tray won't open. I have a library disc in the tray. How do I get the disc out.
Look to see if there is a tiny hole on the face of the tray, if the tray door has a pin-hole, you can use a straightened paper-clip.
Push the paper-clip into the hole...causing the tray to open.
Also, Try holding the eject button while turning it on.
Dec 29, 2014 | Toshiba SD-4800 DVD Player
How do I open dvd tray on hp m8120n?
On all CD/DVD look for a tiny hole on the front tray.. use a paper clip ... insert the paper clip in the little hole... do it gently .. it will open the tray.. ALL CD/DVD have the little hole.. so look for it.. remember the hole is as little as a paper clip .. like a pin head small...
May 18, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
How do I open my jammed door on my e machine
Use a paper clip end and stick it into the small hole on the face of the DVD Tray surface. It is tiny , and hard to see, but it is there. Pus the clip into the hole and it will let the tray slide open.
Mar 02, 2014 | Acer (91.AB264.023) Internal 32x CD-ROM...
DVD disc stuck in vision plusTV/DVD combo
There should be a tiny hole somewhere on the front of the DVD tray, where you put the disk in. If it's not on the tray itself, it should be very close to it. Bend a paper clip out a bit, and carefully press it into that tiny little hole, and the tray should open up. If that doesn't work, then it's physically jammed, and mechanically unable to open.
Jan 31, 2013 | LG 32LG40 32 in. LCD HDTV
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
Drawer won't open
There is a mechanical way of opening it. Straighten out a paper clip, find a very small hole on the face plate of the drawer slide. Insert the straighten paper clip end into the hole and push gently. this will push the unlatch triger and release the tray.
Jan 07, 2011 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
DVD tray won't open
Hello.
Look for a tiny hole in the front of your DVD tray. With the PC off, use an opened paper clip and press in the hole until the tray opens.
Power on your PC and see if the tray now mechanically works.
Be certain that your DVD is present in Device Manager (in Control Panel).
If present and still does not work, replace your DVD drive.
Hope this helps.
Sep 17, 2010 | Gateway GT5220 PC Desktop
DVD drawer won't open and no audio on home theatre system
As far as with dvd and cd players in many devices they usually put a tiny hole under the dvd/cd tray. If you open the door with a precision screwdriver and look beneath the tray for a tiny hole and insert the screwdriver into the hole you will feel a gear, push a little more and this is the "emergency release" the disc should pop right out if it is a tray (not a front loader like ps3!) for the audio i need some more info like connections and what cables are being used, analog or digital. hope this helps you out.
May 05, 2009 | Electronics - Others
Dvd will not reject
Use the emergency eject feature. To do this:
  1. Straighten a paperclip
  2. Insert into the tiny hole on the face of the DVD tray (usually near the eject button)
  3. When you feel a bit of resistance, push the paperclip to eject the tray.
  4. The tray will open slightly, allowing you to gently ease it out manually, and you can then remove the DVD.
  5. Press the eject button to shut the CD/DVD tray again.
Nov 07, 2008 | HP Computers & Internet
Disk Tray
Here is the solution. __Regards,__Arpi
Mar 22, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Sony DVP-SR200P DVD Player Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
