Question about Garden
Tractor mower will crank but not start, new gas, plug and battery
  • 59 Answers
Check the coil it may have rust on it and the fly wheel
Posted on Jun 23, 2009
    Problem Solver:
  • 9 Answers
Any engine has to have 2 things to run. Gas and ignition to the spark plug. You can check the fire to the spark plug by removing the plug wire from the plug and inserting a phillips screwdriver into the end of the plug wire. Try to start while holding the shank of the screw driver very close (but do not touch) to the head where the spark plug screws into. If you see a spark jump from the screw driver shank to the head, you have fire. If you have new gas and fire and it still won't start. Change the spark plug.
3 Suggested Answers
  • 148 Answers
SOURCE: Tractor Won't start
If you are getting a backfire condition your fuel mixture is too rich. This simply means that your carb needs to be adjusted (Too much fuel to air mixture).
Mike
Posted on Aug 19, 2009
huffman49
  • 235 Answers
SOURCE: ys4500 Lawn Tractor will not start.
did you hit something while mowing if that is the case then check the flywheel key. even if it only has a small nick in it that would keep the engine from starting up...good l uck
Posted on Apr 11, 2010
Will a bad drive belt make your riding lawn mower not start?it cranks
Take the spark plug out and see if it is wet with gas. Could be bad cable, bad plug, leak in carburetor gasket
Jul 20, 2016 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
John deere L100 cranked over...wouldn't start...out of gas....added gas, now wont crank over at all
Thou has drained the battery with all your cranking. Recharge unit and now check for spark since you have resolved the fuel delivery issue.
Mar 14, 2016 | John Deere Garden
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
With key my riding lawn mower does not start, not even crank. Nothing happened.
Are you positive that the battery is fully charged? If so check for current reaching the starter motor. If current is there then it appears that the starter motor is no good. If no current reaches motor it is possible the ignition switch is no good.
Aug 27, 2015 | Craftsman Garden
Mower will not start after changing the battery out and checking all connectioncs
U could try to use some starting fluid spray into carb and have someone crank it right away But first do you have fresh gas in the tractor if not I would drain and fill tank with fresh gas. Also I always change my spark plugs at the beginning of the season,
Apr 10, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Ys4500 Lawn Tractor will not start.
Apr 11, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Tractor Won't start
Mike
Aug 19, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
272 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
