Question about Sony DVP-SR200P DVD Player
Disc tray stuck
Where is the tiny hole in the front of the tray? The face of my tray is off but I don't see any tiny holes to open the tray.
2 Suggested Answers
SOURCE: disc tray will not open
I've not found one, no, but I have managed to strip the machine down, get the disc out and rebuild... I guess this is too late for you but it's simple enough if you're still trying.
Posted on Mar 28, 2010
Tray won't open. I have a library disc in the tray. How do I get the disc out.
Look to see if there is a tiny hole on the face of the tray, if the tray door has a pin-hole, you can use a straightened paper-clip.
Push the paper-clip into the hole...causing the tray to open.
Also, Try holding the eject button while turning it on.
Dec 29, 2014 | Toshiba SD-4800 DVD Player
How do open a stuck Polk Audio DVD player?
there should be a tiny hole on the front of the disc tray bezel. Insert a straightened paper clip in there and it should pop open.
Sep 06, 2014 | Televison & Video
My ibm intellistation z pro: nothing appears on the screen no ibm sign at start up no nothing also if i try to open the disk drive it won't open which seems weird
maybe a disc stuck in the drive? if you pull down outter door of disc drive (unless you can see the front of the disc tray already) there is a tiny hole on front of disc tray, large enough to get a paper clip wire into, that will release the tray and pop it open
Mar 06, 2013 | Computers & Internet
DVD disc stuck in vision plusTV/DVD combo
There should be a tiny hole somewhere on the front of the DVD tray, where you put the disk in. If it's not on the tray itself, it should be very close to it. Bend a paper clip out a bit, and carefully press it into that tiny little hole, and the tray should open up. If that doesn't work, then it's physically jammed, and mechanically unable to open.
Jan 31, 2013 | LG 32LG40 32 in. LCD HDTV
Disc drive won't open
CD/DVD drive?
Some have a tiny hole, right under the tray that comes out. Use a paperclip in the hole to manually open the tray.
(Some desktop computer towers have a door in front, that needs to be eased open first, then access to the actual CD/DVD drive unit can be obtained)
Regards,
joecoolvette
Jun 02, 2012 | Dell Computers & Internet
Dvd drive is flashing and wont release dvd and has system locked
Turn the system off completely even if you have to unplug it. Then use a paperclip or equivalent to open the drive through the manual access hole. This is the tiny hole on the front of the tray that will open the drive when the system is off. Remove the disk and restart the system. Don't use that disc. Hope this helps
Jul 11, 2011 | Dell Inspiron 1525 Notebook
My cd will not eject out of the driver. Help!
Just to the left of the eject button and just below the disc tray on your optical (DVD/CD) drive is a tiny pinhole. Open up a one end of a paper clip and push that end into the hole and it will release the tray and pop it out without damaging the disc or the drive.
Apr 27, 2011 | Dell Computers & Internet
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Sony DVP-SR200P DVD Player Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
