Question about Hoover Washing Machines
Where can i find a Hoover 500MB washing machine wiring diagram
barkencoa
  • 3463 Answers
SOURCE: bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Posted on Dec 15, 2008
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
Posted on Mar 15, 2009
SOURCE: do you have a wiring
http://www.washerhelp.co.uk/diy-repair-safety.html
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Above is a generic washer although the wiring won't be exact, it still will be relevant, and eminently transposable to this make. If you simply perform the troubleshooting procedures no doubt you would be able to isolate and hopefully repair your problem
http://service.hoover.co.uk/manuals/pdfs/VHD8122.pdf
Hope this is helpful, i could find little on your exact modle.
Posted on May 13, 2010
SOURCE: Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Posted on Jul 13, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Hoover 500MB
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. I f this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift up hard...picture.Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 25, 2011
My hoover 500mb 5.0kg washing machine fills up fine at start of cycle then just washes for a bit then just stats to fill up and wont stop till I stop it
I had a similar problem and not sure whether my solution would help you.It was to do with the position of the waste pipe.It should raised about 2ft. ,looped before discharged into the washing machine tee.when the discharge hose is lying on the floor there's a possibility that the water is filling up and going straight out.By raising it you are letting it fill up and presumably triggering the water level sensor.Hope this helps.
May 29, 2017 | Hoover Washing Machines
My Hoover 500Mb is extremely loud on spin cycles, it works great but very loud just on spin?
as you have probably found out by now the drum bearings are worn out probable due to the seals leaking ,new set of bearings and seals if not already fitted.
May 25, 2016 | Hoover Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
My machine seams to go slow with a light load 500mb h/duty
500mb from memory was a Hoover top loader ??? It could be just the belt slipping underneath, but also have a look inside the drain pump hoses for blockages. These were notorious for blocking with coins and other foreign objects. . If the machine couldnt pump out properly, when it went onto spin, it would only go very slow as the machine wasnt able to build up any speed with a full load of clothes and water.
Jul 26, 2011 | Washing Machines
I have a Hoover 500mb, 5kg HD Top Loader washing machine. The problem I am having is the clothes always have lint and other stuff on them after being washed. I have tried taking the agitator off and seeing...
have you done a clean ,hoover have this built in you need to do every so often the filter could be clogged do a clean don't put anything in when your doing this ,how old is it
Jun 16, 2017 | Hoover Washing Machines
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Sep 18, 2007 | Washing Machines
Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Dec 09, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
