Question about Fujitsu Plasmavision P55XHA30WS Television
Where can I find replacement sustain modules for a fujitsu plasma model P55XHA30WS?
My Plasma repair technician tells me he cannot locate replacement modules. I am loathe to walk away from this unit I originally paid $11,000 for ..
    Top Expert:
  • Fujitsu Master
  • 74,251 Answers
Posted on May 06, 2014
SOURCE: fujitsu plasma tv connection problem
the fujitsu pds 4222ws uses bnc connectors. they have all kinds of adaptors to use for any type of wire
Posted on Nov 09, 2008
  • 534 Answers
SOURCE: Fujitsu Plasma Automatic turn off after 5 mins
Fujitsu have issued Service Bulletin covering these shutdown problems- see link below :-
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
I suggest implementation of this bulletin by a service technician may cure your problem.
Posted on Jun 02, 2009
  • 534 Answers
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Posted on Jun 05, 2009
SOURCE: Stuck on Standby, Fujitsu Plasmavision: Model pds4229e-b
I had exactly the same problem with a Fujitsu General PDS4208E. After looking at the forums etc bit the bullet and tracked down an ORIGINAL remote. Paid yesterday, arrived today - batteries in...screen back on!! One proviso here: Before you pay big money for an original remote (and ONLY they will work with these 2nd generation plasma screens not universal remotes) make sure that your screen WAS working before it was in the standby mode. try http://www.portables.co.uk/ on +44 208 968 1444. Ask for Andy. He seemed to know what he was talking about. About £50 +VAT plus next day delivery charge. Alternatively borrow mine at £5 a button press!! ;-))
Posted on Jan 26, 2010
  • 32 Answers
SOURCE: Error Message: Condition 1
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
a repair of this unit is possible.
Regards
Posted on May 25, 2010
Testimonial: "Very helpful."
Samsung plasma black line fix
Sustain board fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to Plasma screen are given with illustrations.
Aug 06, 2014 | Samsung Pn50a450 Pn50a450p1dxza 50" 720p...
Purple screen
Sustain board fault. Contact any service technician. It is a skilled work to locate the exact faulty sustain board. Gopakumar Gopalan Google
Mar 09, 2014 | Fujitsu P55XTA51US 55 in. HDTV Plasma...
My fujitsu plasma picture goes blurred and fuzzy after been on a while
Any one among the sustain drive board can be faulty. Contact any service technician and make it confirm. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 01, 2013 | Fujitsu Plasmavision 42" TV
Philips TV, Model Number 50PFP5332D/37, the screen starts out all black, but then slowly the black starts to dissipate and the picture starts to come through. However, the picture is all gray & fu
You more than likely heard a pop noise when this failed, the infamous pop of death when the Y sustain module fails. First check the various fuses located on the Y and X sustain modules. If a fuse is open you have lost the large IC on either PC board. These boards are located left side 3 module and far right side module with ribbon cables attaching to display panel. This can be a complicated repair due to one of the buffer modules failing, The Y sustain will be identifies by Samsung drawing number LJ92-01200A, The Buffers are LJ-92-01202A, LJ92-01203A. This is most likely a job for a pro because 1 of or all 3 modules can be at fault. Some services on e-bay for these modules offer rebuilding the Y-main module and also testing the Y-buffers. If you want to DIY this TV this would be the best Idea, send three boards to a rebuilder on E-bay.
Mar 05, 2013 | Philips 50PFP5332D 50 in. Plasma...
Sonicview vpw425 has red and green snow
Hello!
Good question: this problem caused by aged capacitors in Y-sustain module, plus in a power supply. Bad news: if you keep watching TV, it will quit soon with hefty repair bill. So far, all those modules are in repairable condition. Plasma has very high voltage inside and I won't recommend you to even open the set, unless you are have very good technical/electrical background. If so, let me know. I will guide you throughout the repair. If not: pull the power supply board out, then Y-sustain board. Left side of the set with back open. Y-sustain is a quite complicated to remove off the set. Has many fragile connectors to scan converters, plus ribbon cables. Some might be well hidden. If you forget to unplug those, damage will occur. I, personally, won't recommend any amateur or even mediocre electronics technician, to mess with early plasmas. They very well built and packed inside, multiple rubber heat conductors under those boards, etc. Most likely your set has Samsung PDP, because Panasonic PDP, which has been used in Toshiba as well, won't show this problem. It might intermittently loose a picture, but not a "flies" on a picture. I've seen those, in 50" Samsung and their made panels. Guess what: whoever ignored my warning: fix it now or forget it, already got set busted.
I can help you to rebuild those boards, but you need a service manual to safely remove and replace those.
Thanks,
Alex.
Dec 25, 2011 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJITSU/PLASMAVISION%20PDS4221-_E
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Oct 28, 2009 | Fujitsu Plasmavision 42" TV
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
LG 52 inch plasma screen discoloration
This indicates that one of the intelligence power modules (IPM) is failing on the X sustain board inside your unit. If the picture becomes annoyingly noticeable you will need to have the X sustain board replaced (this component cannot be repaired on the board).
Jan 12, 2009 | LG DU-50PX10 50 in. Plasma HDTV
No picture
Common faults that give you no picture and sound on Plasma are often related to Sustain board, buffer and cables problem.
In this case the cost will be affordable, ans surely worth.
In the unlikely eventuality that instead you have a faulty plasma screen , or a faulty digital control board (main board), the cost of repair may be high.
The only way to find out is by having the TV inspected by a technician.
The most common fault that gives you no picture and sound on plasma is Sustain board , lower buffer, or connector, that is repairable.
Jan 05, 2009 | Televison & Video
I got white vertical line running down a plasma display panel . they are close together that you cant even see on that side of the tv. on a closer inspection they are blue-green-red-blue-green-.... but...
A vertical line running down a plasma display can be caused by :
faulty buffer module.
Fauly sustain card.
Faulty plasma display.
Try unplugging power cable and see if this helps, if it does not , then you will need to call a technician.
In that case call the support number listed on your owner manual.
If warranty has expired, ask for a warranty extension, if available. this is cheaper than repair cost, and will cover the repair.
Jan 04, 2009 | Sony PFM-50C1 50 in. Plasma HDTV
Fujitsu Plasmavision P55XHA30WS Television Logo
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
