Question about Samsung Computers & Internet
Vga failure what is the cause of machines inability to shoot on the screen?
  • Samsung Master
  • 2,013 Answers
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Posted on May 28, 2014
Pain on left side like spasm
Pain on left side causes of the spasms are unknown, but can be triggered by mental stress, improperly carrying a heavy object, or stretching too much. People with sedentary lifestyles are more prone to back spasms.The typical symptoms of this kind of left side pain are inability to bend in certain directions, and sharp shooting pains. http://www.elswickchiropractic.com/
Aug 09, 2013 | Cars & Trucks
Phillips 42FPL7662D/05. I do not know why the tv has stopped displaying a picture. The power supply is okay. I have taken the back off, there does not seem to be any problems with any soldering. If you...
if still the sound is working but with out any picture the cause would be a screen back light failure or malfunction in the t-con board. if the totally black screen it was a failure in the back light, you will need to remove the back cover to access this part. it was located at the upper and lower portion of the panel display covered with metal shield.now if the display is only a white screen you can see it in dark room, then the cause will be a failure in the t-con board. the t-con board was mounted underneath covered with metal shield.before you come up with trouble shooting the t-con board tried first with re seat the connectors which have loose contact.hope this can help good luck.
Nov 17, 2012 | Televison & Video
WHITE SCREEN
hi if your monitor just display with white screen no picture the cause would be a bad lcd controller or bad lcd panel. but before you come up with trouble shooting inside of the monitor you can check first a loose connection in the vga port or tried with replacing a new vga cord.just let me know if you need further assistance i'm glad to help you good luck.
Nov 05, 2012 | ViewSonic Computers & Internet
What is the video memory of a Compaq Presario SR5712F PC Desktop
Description---- Problems with video cards show up as intermittent system lockups when playing 3D games, small dots of color spattered across the Window desktop, the inability to run certain 3D games, and the inability to open Windows normally. All of these issues can occur because of video hardware or driver problems. Find an item below that matches your video need: For integrated video memory that is adjustable, use the following steps to change the amount of video memory (RAM) from the PC BIOS Setup:
  1. Turn on the PC.
  2. When the blue HP screen appears, press the F1 key. Entering Setup should appear on the screen.
  3. When BIOS Setup screen appears, use the RIGHT ARROW key to select the Advanced screen.
  4. Use the down Arrow key to select the video memory setting; for example; VGA RAM Size, integrated video, or On-Board Video Memory.
  5. Press the Enter key.
  6. Use the down Arrow key to select the desired amount of memory or memory setting that is listed and then press the Enter key. CAUTION: Do not select a DISABLED setting without a video card installed! Doing so can cause the monitor to go black until a video card is added or the BIOS is reset.
  7. Press the F10 key, and then press Enter to save changes and exit. The PC is set to use the new video memory setting.
tell me if this was helpful
Apr 26, 2010 | Compaq Presario SR5712F PC Desktop
My hp dv6000 in going hot after a few min. why?
This is the intensity of heat the processor and the inability of the cooling fan can cause overheating in this failure in part card that beats the screen and my advice to you, but you run the machine a lot that can solve this problem
Apr 17, 2010 | HP Pavilion dv6000z Notebook
My dell GX 1 optiplex pc is not powerring and power supply is not
Hi:
If you don't have the LED lit up on the board, the most likely failure is your power supply. You should be able to get a computer store to test it, to be sure, but a replacement is $30-40
Nov 24, 2009 | Office Equipment & Supplies
The screen starts to twitch with some glithces then goes black
if it is became black totaly... there are a lot of causes..
1. lcd screen.. maybe some problem.. or factory deffect
2. inverter -need to check up
3. vga cable or lcd cable...- maybe loose only
4. vga chip or video card..
just do basic trouble shooting.. check the inverter. then vga cable use another or new inverter or vga.. or use new lcd screen.. if the same that is need to open and check up the vga chips or video card..
Sep 09, 2009 | Samsung NC10-14GW Notebook
Toshiba Satellite Laptop 1115-S103 trouble shoot VGA & projector
it should be f5 if not then look for an icon that has a computer screen on it
Apr 08, 2009 | Toshiba Satellite 1115-S103 Notebook
Dell latitude d600-vga
The flickering may not be caused by a corrupt driver, it could be the impending failure of the fluorescent back light of the display or its high voltage supply.
Trying driver replacement though is the first thing to try.
If the original driver is corrupt, you can try the following;
- Right-click on My Computer
- Left-click on Properties
- Click on Hardware tab
- Click on Device Manager
- Locate and open Display Adaptors
- Locate the video listing for your
- Highlight and delete this
- Reboot the computer
If Windows does what it should (no guarantee on this!), it will 'find' a 'new device' and install the driver for it.
Aug 23, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
48 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
