Question about Daewoo DTQ-27S2FC 27" TV
TC not turning on at all after switching from Video-TV input
Could anybody tell what the problem could be?
TV was working fine and suddenly when changing inputs with the remote, I heard a funny noise (like TV turning off but louder) anddidn't work any more.
Fuses and power supply seems to be fine.
Any suggestion is appreciated.
  • valente_gonz Jun 22, 2009
    Thanks. That's what I'm afraid of. I don't think is worth to replace the picture tube. Do you know if it's an cheap way to repair it?
  • 258 Answers
By what you are saying looks like the picture tube has blown, I would need to look over it so best bet is to take to your local tv repair centre
Posted on Jun 22, 2009
  • Brett McGuigan
    Brett McGuigan Jun 23, 2009
    well I would need to open it up and take a look at it, don't try this yourself as you could electrocute yourself, these devices hold alot of electrical charge in their capacitors even when they have be unplugged for days, there could be some blown circuit components inside, best bet is to take to your local tv repair centre, and ask for a free quote on how much to fix ok
Panasonic TV, TC-P50S2.Yamaha DVD Player DV-C6280.Yamaha Receiver HTR-5450.DVD audio working fine thru receiver. Not sure where to place white/yellow cords to get video feed.
Hello. Usually when you mention white and yellow, there should be a red also, the red and white are right and left audio and the yellow is the video. The audio should be connected to the receiver, and if the receiver has video inputs and outputs, that should be connected to the same receiver input as well, but if the receiver doesn't have video capability, the yellow should be connected to the TV video input. I hope that helps.
Aug 01, 2016 | Panasonic Televison & Video
Panasonic tv hdmi inputs not working
It appears that during the storm there may have been an electrical surge that damaged the electronics of your tv. If the tuner is working fine then the affected area (board) is the one that has the HDMI input sources.
Aug 30, 2015 | Panasonic Viera TC-P58S1 58 in. Plasma...
I have a insignia ns-pdp50hd-09 plasma tv that has sound but no picture
You may try using the power switch on the TV itself instead of the remote. I have had trouble where the remote turn on doesn't work for the video, holding down on remote button longer seem to help.
Also you may want to try another input to the TV -so connect up input wires from your cable/sat to another one.
Jul 01, 2014 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
I have a Hikona TC 1400 TV and after the digital switch over now need a digibox to watch freeview etc. I have purchased a digibox followed the installation instructions but the tv is all blue with no...
With a digital set top box, you do not need an antenna for your TV. You need to switch the TV to whatever input you have connected the TV to. Usually the set top box is connected to the TV by an HDMI cable. Take a look at what input on your TV the cable connects to, and then set the TV to that input. It should then work fine.
Jan 03, 2018 | Televison & Video
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
Toshiba TN55X Convergence problem.
You brought up an issue that we hadn't considered. Shortly after hooking up our TV to the receiver with a composite video, our convergence which wacko. My hubby replaced the 2 ICs, but now our power button just flashes red, with no picture. Not sure if new ICs are faulty or if it's another issue. He will replace old ICs to see if problem still exists with turning on the tube. And he'll try disconnecting the video signal to see if problem exists.
Ouch.. may have to consider another tv thanks to new technology ??????
Good luck solving your problem.
Jul 06, 2008 | Toshiba TN55X81 55" Rear Projection...
TOSHIBA 35 TV 35A44
don`t know if this will work for yours but I have heard of menu coming up all by itself randomly and the fix was to remove the batteries from the cable boxes remote and the tv`s remote, partially stuck on buttons were the cause, replaced the remote end of problem, hope this helps on yours.
Nov 29, 2007 | Toshiba 35A44 35" TV
Composite and s-video inputs stopped working
You may have shifted the input board a little while replaceing the IC's. Double check every plug and connector, not just by visuale inspection, but by going and removing and replacing every connector. I have had problems like this in the pasy and have learned the hard way, everything is not as it looks. Good Luck
Jun 04, 2007 | Philips 60PP9202 60" Rear Projection...
No video
yea since the tv was replaced you can call the same technician and let him repair the tv the problem is in the video section or related circuit.good luck.
Apr 16, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Daewoo DTQ-27S2FC 27" TV Logo
78 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
