Question about Samsung SCX-5530FN All-In-One Laser Printer
Printer samsung Internal error Power Off/On BB_Data Mgr.c 477 ROOT
3 Suggested Answers
alfi819
  • 65 Answers
SOURCE: samsung printer ml-2551 internal error
Make a service request here or contact Samsung here
Posted on Mar 27, 2009
kalpeshbhaws
SOURCE: internal error mdlcrum 0094 in samsung printer ml-2550
I HAVE A PRINTER SAMSUNG ML 2550 ERROR CODE MDLCRUM 0094
Posted on Sep 26, 2012
How to recover data from a samsung old flip phone
Here is a guide you can follow:
Before recovery:
Enable USB Debugging Mode. For most phones, you can find the option on your phone through: Settings > Developer Options > USB Debugging. If you can't find the option, please type "phone model + enable USB Debugging mode" in search engines to get detailed guides.
Root your phone to get root privilege. Rooting means gaining root access to your device, so that the program gets permission to scan your phone. Since there are so many Android OS versions and phone brands, it's hard to find a single tool that can root all devices in high successful rate. Here are some commonly used root tools: iRoot, Kingo Root, oneclickroot, Root Genius, etc.
Connect phone to computer via USB cable. Please make sure it is well connected, otherwise recovery result will be disturbed.
Step 1: Launch Eassos Android Data Recovery software, and click "Refresh Device" to detect the device. The program will show storage devices in your phone and display internal built-in memory (internal storage) and memory card separately.
Step 2: Select storage device and click "Next". Then this Android data recovery software will make image and search for lost data automatically. connect-device-to-computer-l4z23du0euvv25ewe4orlrwr-4-2.png
Step 3: After a while the image is created and the software starts to scan it and display lost files.searching-l4z23du0euvv25ewe4orlrwr-4-5.png
Step 4: Preview files. Double-click file to open it and view its content and files like photos, video, audio, documents, etc. can be previewed.
Step 5: Select files you want to recover and click "Recover" button to save them to a secure location. Alternatively, after selecting needed files, you can right click mouse and copy files with context menu.
Jun 11, 2017 | Samsung Cell Phones
My printer sho this errors messages:BB_DataMgr*477 ROOT
Dear
Pl. do re-jack the connectors if possible do the firmware update,replace the mother board in most cases.
Thanks.
Mar 17, 2015 | Samsung 6322dn
Printer stops printing after first page and show the following on the second page: INTERNAL ERROR - Including Corrupted Data POSITION : ox23759 (145241) SYSTEM : h6fw/x1_image VERSION : SPL 5024...
Try disconnecting your printer from your pc and then uninstalling the drivers for it in your control panel. Go to the manufacturers website (Samsung) and click on the drivers and sofware area to download a new copy of the files necessary to run it.
After installing, reconnect your printer to your pc and try printing a test page to see if this has corrected the error.
Jan 16, 2011 | Samsung ML-2570 Laser Printer
Impressora xerox 3300mfp aparece o seguinte erro: BB-data mgr.c 487 internal error wer: off/on
Ese error lo manda porque ya la bateria de respaldo que lleva en el tablero(generalmente de 3.6 volts) ya lleg? al fin de su vida y hay que remplazarla, en mi caso me lo hizo en una Dell 1815, pero la marca fabricante es Samsung, abarca Dell, Samsung y Xerox, esas bater?as eran tres marca Varta tipo bot?n grandes en serie de 1.2 volts que sumaban los 3.6 volts,como son muy dif?cil y caro el conseguirlas lo que hice fue soldar los terminales de los cables positivo y negativo a una bater?a de celular recargable que ten?a el mismo voltaje y se lo pegu? con silic?n a un espacio en el tablero y ya funcion? bien.Ojal? y este tip les sirva.Les mando un saludo amigos.
Dec 01, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
My samsung ml 2571n print only the first page
motherboard faulty,cannot process data.change
Jun 18, 2009 | Samsung ML-2571N Laser Printer
Internal error mdlcrum 0094 in samsung printer ml-2550
Mar 27, 2009 | Samsung ML-2550 Laser Printer
Samsung printer ml-2551 internal error
Mar 27, 2009 | Samsung ML-2551N Laser Printer
Samsung SCX-5530FN internal error power on/off
It is not possible to scan to email anymore. Also the copier makes noise when copying and the result is blurred and illegible.
Jan 22, 2009 | Samsung SCX-5530FN All-In-One Laser...
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Jan 20, 2009 | HP LaserJet 4350dtn Printer
Samsung SCX-5530FN All-In-One Laser Printer Logo
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
