Question about HP Photosmart D7160 InkJet Printer
ERRORE 0xc18a0201 NON STAMPA E MI DA ERRORE Oxc18a0201
Where is the reset button on the ricoh 1600?
Buondi' la macchina non riconosce il formato a4 in fase di stampa
mi dice sempre di mettere la carta nel by pass cosa posso fare?
grazie
May 14, 2014 | Ricoh Aficio MP 1600 Black and White...
Tip
Io ho provato però non mi stampa bene la stampa bene le stampe.
[Although specifically written for an MX310, this should work for all MX and MP series Canon printers.]
If this Tip does not work for you, please notify me by accessing my profile page at here and using the Ask button to write me a note.
I can then help you with your specific problem.
Error Code U163 (Ink Cartridge Empty or Low)
First of all, Yes, this is a common problem.
When you open your printer up, by lifting the Scan Cover, you will see lights blinking for the cartridge that is low or is empty.
1.) A lamp blinking once every three seconds means your cartridge is low.
2.) A lamp blinking once every second means your cartridge is empty.
Using your printer with an empty ink cartridge is capable of harming your printer, according to Canon Engineers.
Until such time as you can replace the cartridge you can use the method described below to temporarily turn off the error message.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again.
Regards,
Worldvet
NOTE: If this doesn't resolve your Canon problem and you want to try another Tip that may work, you can try this Tip written by Darklord. At least give it a read, it has been known to reset some Canon printers.
on Apr 18, 2011 | Canon PIXMA MX310 All-In-One Printer
Message Code: CA1
ANCHE A ME MI DA CODICE MESSAGGIO CA1 E NON MI DA LACCESSO AL POKER MI RESTA DI PENSARE CHE SIA TUTTA UNA TRUFFA AL QUADO ANCHE COMPRANDO CIPS NON MELE INVIA
Mar 05, 2011 | Zynga Texas HoldEm Poker
Salve ho inserito la chiave di rete nel router belkin che ho acquistato e funziona ma ora ho un problema mentre il pc entra in automatico con il cell. IPhone ogni volta mi chiede la chiave di rete...
non solo emette segnali router Belkin e tutte le reti wireless dipendono da una singola password, controllare il prodotto in modo da poter ottenere Connected
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
Kodak easyshare5300
salve,
è sicura di aver rimosso la pellicola protettiva dalla cartuccia?
altrimenti potrebbe essere la cartuccia difettosa.provi a richiedere una sostituzione.
Spero di esserle stato d'aiuto
Riccardo
Jul 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon pixma mp 210
hej ljudi kako da resetujem kertridze za moj canon mp210,posle prvog punjenja ne radi.
Apr 04, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Not Printing.....
Dovrebbero essere le testine di stampa intasate dall'inchiostro essiccato (succede soprattutto con cartucce non originali). Prova a smontare le testine, e tenerle a bagno per una nottata in un solvente specifico (io ho usato del semplice acetone ed ha funzionato). Quindi imbevi nell'acetone un capello (non è molto elegante, ma funziona) e cerca piano piano di inserirlo nei micro fori presenti sulle punte che forano le cartucce di stampa fino a che non risulteranno pulite. Quindi rimonta il tutto ed in bocca al lupo.
Max
Dec 19, 2007 | Epson Stylus CX3200 All-In-One InkJet...
HP Photosmart D7160 InkJet Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
