Question about Brother MFC Office Equipment & Supplies
Faded color prints
PRINTS COLOR FADED AND WASHED OUT. ALL OTHER PRINTING PRINTS GREAT. JUST COLOE PHOTOS
  • 39 Answers
* If your are printing color photos on a Glossy paper you must chose the paper type from Media Type in the Printing Properties while giving Print command. If you don't know what is the type of your glossy paper then just select other glossy paper from the given options. faded color prints - f91a3a39-5f37-45c6-9bca-21ac453f79ef.gif
Posted on Jun 10, 2014
WhIzAtIt
  • 136 Answers
SOURCE: faded color photos
HAve you tried uninstalling Canon's software and reinstalling?
Posted on Sep 15, 2007
  • 16 Answers
SOURCE: HP Photosmart C6180 All-In-One Is printing All Documnets Faded Colors
Try to clean your printheads or check the level of your inks, maybe you are low on inks. Operating system does not affect any printing outputs as I know. Check your inks also coz HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.
If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
Replace any empty print cartridges. To check ink levels, follow the steps below.
  1. Press the Setup button.
  2. Press the down arrow button until Tools is highlighted.
  3. Press OK .
  4. The Display Ink Gauge selection should be highlighted. Press OK and the ink gauge will display.
OR try calibrate the color:
  1. Open the printer Toolbox :
  • Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
  • If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
  • Click Settings .
  • Click Print Settings .
  • Click Printer Toolbox .
2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
If the steps above did not help, clean the print head.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Please let me know if these steps helped you or not. Thanks
Posted on Jan 05, 2008
SOURCE: Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Posted on Dec 11, 2008
  • 32 Answers
SOURCE: Light or Faded Areas in Solid Color Prints
If the issue is occuring in the same place on all prints, try the imaging drum (can't remember if this printer even uses one) or the transfer belt/roller (not sure which it uses). If you phone Dell support, they should run you through troubleshooting and send you either of those parts free of charge if you are under warranty. If not, buy them anyways; they don't degrade over time (if kept in the dark) and can be saved for when the currently installed one runs out if you don't need it to fix this issue.
Posted on Jan 05, 2009
komguy
  • 2306 Answers
SOURCE: color photos printing very faded
Some nozzles could be burned out on the printhead, and you need to make sure you have no photo inks installed where regular inks should be. Photo magenta prints much lighter than regular magenta.
Posted on Aug 12, 2009
I cant print photos on a paper they look faded when i print them and when i print a leter or words it prints really well, the printer is a canon pixma mp130...do you know what the problem might be ?
my canon mp250 won't print color photos it does well with BW but not color. I took back the first one I had did the same thing now the second one won't print color photos off the internet. what did I do wrong? Both inks are brand new.
Jan 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Color photos printing very faded
Aug 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Very slow printing
I'm not sure that there is a problem here.  The correlation between print speed and print quality,
especially on InkJet printers, is a negative one.  That is, the higher the quality setting, the lower
the speed. So, if you're selecting the greatest quality for your print option you will suffer the
lowest output speed.  This is because the printer is taking time to ensure that it prints each
minute detail onto the page.
If you are looking to keep the quality optimal, one solution may be to select a different grade of
photo paper (or perhaps one with a different coating [matte, semi, gloss]) and test to see if you
can lower the quality setting on these higher-end paper types and still achieve your desired
results.
To get what you want from your printing paper, you will have to consider what you like in a print,
how you intend to use your prints, and what you are willing to pay to achieve this at home.
Some things to think about include: paper thickness, color brilliance and resistance to fading.
1. Paper Thickness
When it comes to paper thickness, paper that resembles the look and feel of traditional prints
will be the best if you like to print a lot of photos and pass them around. Thick paper just feels
right in your hands and will also stand up better to handling. However, if you are going to put
the majority of your photos straight into an album, a thinner paper may work just as well for you.
2. Color Brilliance
To ensure the photo paper you purchase produces good color, you can purchase small sheaves
of a short list of photo papers which you think will suit you. Next, print a series of colorful test
photos on each to see which has the best color. If you can incorporate colorful photos that also
have prominent straight lines and people in them, you will also be able to check the quality of
sharpness and skin tones in the same test.
3. Resistance to Fading
Always try to check the resistance of the paper to fading. Simply take your batch of test photos
and tape them to the window that gets the most sunlight throughout the day. Then, before you
go in to pick up a batch of replacement paper, check to see which photos, if any, are showing
signs of fading. Any paper that shows signs of fading in this short time frame should be avoided.
4. Changing Your Ink
It is also important to remember that any time you change ink for your printer, you may find
yourself getting dramatically different results.
Jan 09, 2009 | HP Photosmart 2610 All-In-One InkJet...
IP4000 Color prints look washed out/yellow
Check the custom settings in the printer properties. Try playing around with different settings till you find the one that suits you best..
May 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Color fading
Hi , the printer are dried up need head cleaning twice then test print , if color of test print are complete color no spaces ,it means head are clean .
Jan 18, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Pimxa ip-4000 printer - black color on photos
did zou refilled the cartridges?
Have you try another paper?
Jan 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Faded color photos
Sep 14, 2007 | Canon PIXMA iP1600 Printer
364 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
