Question about Air Tools & Compressors
AIR PRESSURE SURGES ENGINE DOES NOT
IR 185 COMPRESSURE DO NOT KNOW AGE BUT SEVERLY NEGLECTED
  • 76 Answers
You have a compression leak most likly around a seal that is trying to still do its job
Posted on Jun 22, 2009
I have a 175 pull behind IR compressor. When trying to set the high Idle I open the valve so that it is reading 100psi, the motor trys to throtle up but it seems under to much of a load. also when it drops...
100 psi is around the pressure that the engine goes back to idle
it should start to go to fast rpm when the pressure drops to around 75 psi
if it is trying to increase rpm at 100 psi , the engine is under load and that is your problem
Dec 19, 2017 | Ingersoll Rand P185WJD Platinum Series Air...
How to calculate cfm of air compressure . we have required one air compressure having 7bar-10 bar pressure how much cfm it will have
If you are still looking for an answer to this question, here is a website that will explain how to calculate CFM of an air compressor...
http://www.ehow.com/how_5001852_calculate-cfm-air-compressor.html
Jun 26, 2010 | Atlas Copco LS 16 Hydraulic Cut-Off Saw...
Too hot little cold
Very possible your condenser is extreemly dirty and is turning off on a high pressure cutout. suggest you clean out condenser with compressed air. Brushing is not enough. also, check if condenser fan(at the compressor) is working.
May 21, 2010 | LG Heat cool Window Air Conditioner
(8 Bravda old. air condion inoperative Freon
how do you know freon is ok it sounds like it is low and the low pressure switch is cutting compressor off and back on
Mar 24, 2010 | 1998 Oldsmobile Bravada
Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
COMP SURGES ENGINE DOES NOT
ok I need the model and manufacture. What engine does it have?
Jun 22, 2009 | Air Tools & Compressors
Keeps stalling out
It sounds like you will have to adjust the governor system to hold the throttle on the motor open more so it doesn't bog the motor down. There should be an adjustment screw at the carb to perform this.
Hope this helps
Apr 06, 2009 | Air Tools & Compressors
Compressor oil
PLease contact IR http://www.irtools.com/serviceandsupport/techpubs.aspx
and direct this question to them. You do not want to make a mistake here as it will cost you a compressor. I would only accept what IR says is acceptable
good luck
Mar 06, 2009 | Air Tools & Compressors
Rooftop unit economizer not responding. I tried to simulate hot ambient temperature, but compressor did not kick in, check the resistance of OAT sensor and it's good.
1.check spare parts of compressure.
2 check wireing of compressure.
3. check voltage.
4.check continuti of compressure.
5. check discharge pressure.
Apr 04, 2008 | Heating & Cooling
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
