How do I unlock the controls on a frigidaire ltf2140es3 front load washer
My frigidaire ltf2140es3 front load washer says the controls are locked and I can't do anything, even the laundry. How doI unlock the controls
  • 1294 Answers
SOURCE: E70
All w/machines have a maximum load capacity. Look for yours in the users'manual. Overloading could give you problems, bearings, etc. Your machine cld even have a half load switch.
Posted on Apr 11, 2007
  • 1294 Answers
SOURCE: CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on May 30, 2008
jsrock516
  • 5911 Answers
SOURCE: washer control is locked
The following link explains how to correct a Control Lock problem for your washer:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
I know this link is for Kenmore Elite and Whirlpool Duet. The newer model Maytags are manufactured by Whirlpool (which also makes the Kenmore Elite) so these instructions should apply. Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
Posted on Aug 15, 2009
Jahn27
  • 1554 Answers
SOURCE: frigidaire frontend washer LTF2140ES3 will drain not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Mar 10, 2010
  • 33 Answers
SOURCE: The door lock on my frigidaire washer
The locking mec is jambed or broke easy fix hope this helps
Posted on Apr 29, 2010
I need a chart showing the error codes for a front load fridgedair washer model LTF2140ES3
Hi Richard....Google - Frigidaire front load washer error codes.
There are several links with code listings. Try the Sears Parts
Direct link.
Regards,
Dennis
Oct 10, 2014 | Cars & Trucks
Frigidair LTF2140ES3 has no power to start switch, (good power at wall connection)
Hello Frank Webb - Does the cord or plug look damaged? If it does not, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, I suggest contacting a professional to move forward accurately. The unit may possibly be experiencing an issue with the control board, faulty door lock assembly, faulty pump, or the timer itself is not operating correctly.
Dec 29, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a front loading clothes washer model ltf2140es3 it use to work great, we moved and now it does not spin , whats up ? it was born in 2006
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Loc coming up on frigidaire washer front load
The controls have been locked unintentionally and this is a safety feature to avoid having someone accidentally stop the washer or modify the cycle. It can be unlocked by pressing and holding the OPTIONS and SELECT buttons for 10 seconds or until the "LOC" is no longer displayed. Lock the controls with the same buttons and in the same way until "LOC" is displayed alternately with the estimated cycle time.
Jun 19, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontend washer LTF2140ES3 will drain not spin
Mar 10, 2010 | Washing Machines
Loc code
the control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
Oct 23, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire LTF2140ES3 washing machine. No matter what I select, I hear the door lock click, and then random clicking as it tries to go through the modes, but nothing happens.
sound like you need a door lock. your door lock is not locking or not tell the control that it is locked.. should try 6 times to lock before it will give up trying... hope it helps
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer LTF2140ES3
Go to frigidaire.com then to the manual section click on that manual and it will give you all the information you need. At least yours gives you the code, mine wont do anything!!
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
